I used premier 6.5 to convert a couple of avi clips to an mv2 and and an uncompressed wav. I would like to use this small one minute movie as an intro to other movies that I encode to mpeg2. What authoring program is good for accomplishing this? Can I use the little movie so that it immediately connects to the larger movie? Any suggestions would be appreciated.
Thanks in advance,
VC
This is so much fun!
Almost any authoring program will allow you to do this. I personally use DVD Maestro, but Ulead, TMPGenc, neoDVD, etc. all allow this. In fact the only program that I know of that does NOT allow for multiple files is IFOEdit
Should I multimplex the m2v and the uncompressed wav prior to importing to an authoring program?
Thanks in advance,
VCThis is so much fun! -
If I want to join 2 Films together I do this.
Convert both films to m2v and audio. Author both films, then join in IFO Edit using only the VTS files of both films. I know this is the long way but it always works.Keep going till you get it right!!! -
Originally Posted by videocheez
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 06:30 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
Why does DVD Shrink add RC protection to its files?
By takearushfan in forum Newbie / General discussionsReplies: 5Last Post: 7th Feb 2010, 12:32 -
Video files I add more for a burned disc won't read on my DVD recorder
By Indrek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Jan 2010, 07:30 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
