I got a Panasonic E30 from Singapore which can take both NTSC and PAL system.
Does the E30 selled in US market can also take NTSC
and PAL system?![]()
Is it possible to change the top menu pic before I finalized DVD-R?
Is it possible to play the finalized DVD-R segment bypass the top menu?
Would you tell me some tips about E30.![]()
Thanks in advance.
David Tang
Yep..As far as i know all E30's are switchable bewtween PAL and NTSC.
Tips ??..Ok.. heres a goody. Before using a DVD-R. 'Tittle' it and then if its not gonna work youll find out then and not a few seconds into the film you are recording.
Another tip. Get a DVD drive in your PC that can read DVD-Ram disc (I got a Toshiba one for about £30), you can then record stuff onto DVD-Ram discs n use your PC to edit out adverts n stuff.
This sort of answers your questions about changing the menu, put your DVD Ram or DVD -R in your PC and use DVD authoring sotware to re-author it and make your own menu.
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
Help!!! E30:00 Error Code on (old) Sony DVP-S500D ???
By mlloyd1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Oct 2011, 14:12 -
How to rip BD with top menu + hd audio?
By dougw03 in forum Blu-ray RippingReplies: 6Last Post: 10th Jun 2011, 14:55 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 13:19 -
Bad burn - Panny E30 or TY disc?
By jdachik in forum MediaReplies: 5Last Post: 21st Jul 2007, 11:42
