Does anyone know of an application other than Photoshop or The Gimp that can export .psd image files to HTML?
Preferably with a trial or demo version.
Cheers.
paintshop supports psd.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Can it export the .psd files to HTML?
Reason that I am asking is that I downloaded some website templates that are in the PSD format and then using Photoshop (or any program that supports PSD files) you export them to HTML.
Problem is that they require Photoshop 6/7 and I only have Photoshop 5.5. I also tried the Gimp but it is too buggy in terms of the exported HTML file. -
send them to me or give the link...
or if u rather.. download the demo version of Ps7.
I think i know how to export using Image Ready.. -
Are you sure WeedVender? Just that I have like 20 or so.
Cheers for the offer. -
I have a cable modem.. that is very fast..
just give me the link and I will send it -
www.myfreetemplates.com
Thanks for doing it again. Just try doing a couple because I am getting a copy of Photoshop 7 soon so hopefully I will be able to do them myself (thats the plan anyway).
Cheers.
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 15:02 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
Bending a PSD in after effects
By sk8_aholic in forum EditingReplies: 2Last Post: 15th Dec 2008, 19:29 -
Jagged edges upon PSD inserting in PPro
By Vially in forum EditingReplies: 0Last Post: 12th Sep 2008, 16:34 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 19:28
