Results 1 to 10 of 10
  1. I'm trying to find out what I would need to transfer 8MM or Super 8 to DVD..What I'm asking is what device will be able To work with both..
    I need the playier (RCA or S-video )capable and where to get it.
    If you know Please let me know and Thank You..
  2. First you need some form of capture device. Then look here:
    https://www.videohelp.com/capture
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Are you talking about FILM or VIDEO because Super 8 is a FILM format or do you mean Hi8 which is like Super VHS for the 8mm video format?
    - John "FulciLives" Coleman
  4. Anything that will play both
  5. Member FulciLives's Avatar
    May 2003
    Dude !!!
    I mean really !
    Are you talking about the 8mm and Hi8 video formats or the film formats. As I said Super 8 is a film format.
    Like "Anything that will play both" is not a proper answer!
  6. Dude !!!
    I mean really !
    If someone gives 8mm film then I need the hardware to transfer it.
    If someone gives Hi8 I need the hardware too do that to..
    I need to know what is needed to do anything in this area
  7. Member FulciLives's Avatar
    May 2003
    Dude !!!
    I mean really !
    YOU ARE UTTERLY COMPLETELY CLUELESS
  8. Hey all I want to do is to transfer the information from 8mm film or Video to a VCD or DVD or Hi 8 what ever a person gives me.... And my DVD's come out very Good With DVC80 and DVDcomplete.......
    Yeah I might be clueless but I'm trying sorry for not asking the right question
  9. Basically you will need hardware that is capable of playing whatever format that you want to capture, with an analogue output that can be connected to your capture card. Whether this be super8, hi8, VHS, SVHS then that is up to you to decide there is no one piece of hardware that is capable of playing all formats.
