Hi everybody! I'm converted about 50 divx movies to vcd. I decided to start playing around with the bitrate and resolution on my vcd's. I have a panasonic rv27 dvd player which won't play xvcd. What I've found is I can raise the resolution upto 720x480 and the bitrate upto about 3500k/bps mpeg1 stream!,and still fit a 120 minute movie on 2 80min cdr's! The quality is amazing! I'm wondering if anybody has any idea why this works? I thought vcd had to meet pretty strict requirements to play in dvd players! thanx
Results 1 to 9 of 9
my dvd player plays up to 8000 kb/s at 720x480. vcd is 352x240 at 1150 kb/s. anything else is an xcvd.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Yeah but the weird thing to me is that my dvd player isn't supposed to play xvcd! any tips on resolution and bitrate maximums?
The maximums vary from one player to another. You'll just have to experiment.
Your player might handle XVCDs even though it's not listed in the compatibility list because the manufacturer may have changed the player without changing the name or model number. Most companies buy the parts for their players from other manufacturers, they might have changed suppliers or components partway through production. -
OK! is it better to go with lower resoltion and higher bitrate or higher resolution with a little lower bitrate? thanx again
its better to go with a lower resolution and higher bitrate than high resolution and lower bitrate. the higher bitrate will look smoother. the lower will have macroblocks as soon as something moves too fast.
Can the resoltion be anythingxanything or is it better to try and stick to the 480x480,640x480 and etc.. in other words should ya stick to the accepted standard resolutions.
i usually stick with 480x480. looks great on a regular tv, especially at high bitrates.
Bitrate and resolution advice.
By ShinKyo in forum Video ConversionReplies: 9Last Post: 20th May 2010, 13:01 -
Determine best bitrate for a given resolution
By cd090580 in forum Newbie / General discussionsReplies: 7Last Post: 29th Oct 2008, 16:32 -
Resolution/bitrate for small LCD
By jkleslie in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2008, 13:16 -
Questions about video resolution, and bitrate
By jay_lubb in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2007, 14:46 -
Bitrate Vs. Resolution
By KibaOokaminosuke in forum DVD RippingReplies: 4Last Post: 2nd Jul 2007, 18:35
