Had a XVID file and converted it to NTSC Film SVCD using TMPGenc.
Then used the header trick solution to enable my VCD DVD player to play SVCD.
Problem is that I am unable to change the MPEG-2 type using multiplex option to MPEG-1.
Steps I follow are
1. open TMPGEnc version 2.58
2. disable wizard
3. File...MPEG tools
4. Select Multiplex
5. Add MPEG-2 file
6. Change output file name
7. Change type in dropdown list to MPEG-1 (non-std)
8. run.
After this I closed TMPGEnc then reopened it and went back to multiplex reopening the new file only to see the type is still a MPEG-2 file.
What am I doing wrong?????
ok after u do your settings and hit ok than click on save or save as and save the settings you used as a template the reason there changing back is because u didnt save and thus its reverting back to the original settings
Its always funny when it happens to someone else -
Thanks for the reply but I am now confused.
I have a finished MPEG-2 file and through the Multiplex option under MPEG Tools am changing its reading format from MPEG-2 to a MPEG-1 while still keeping the MPEG-2 internal structure.
After I hit run (step 8) I have no other options. Cannot use save as to do that I have to close the MPEG Tools option. Thus I am no longer dealing with that file or its settings.
Thanks anyway.
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 08:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21
