hello, i have a movie file with the .bin extention, i have read a few posts that say i should alter a line in the corresponding cue file with a text editor, and then i should be able to burn the file on a dvd-r using nero. the problem i have run into is, every text editor tells me the .bin file is to large and won't open it. is there a tutorial that explains the steps to take to convert .bin files to dvd files, or something that will let me view this movie on a stand alone dvd player? thanks for any help.
why are you trying to open the .bin file to edit the .cue file?
the .cue file should only be 2 or 3 lines of text.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
- housepig
Housepig Records
out now:
If you ONLY HAVE THE BIN FILE, then you will need to regenerate a new CUE/BIN image.
I suggest that you use the CUE/BIN Regenerator tool in GNU VCDImager Tools GUI here: http://www.michaeltam.com/vcdimager_tools_gui.html
After you regenerate a new CUE/BIN image, you can burn that with a number of burning proggies including VCDEasy/CDRDAO, CDRWin and Nero.
This is assuming your BIN file is actually an image of a S/VCD of course.
Regards.Michael Tam
w: Morsels of Evidence -
_________________
- housepig
there is no .cue file, so i'll try to regenerate, one as one of the other replies suggested.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 02:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 08:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
