hello guys,
i am getting this message
"illegal floating decimal point calculation order"
can anyone help,please?
thank you all in advance
If TMPGEnc freezes or crashes when converting or you receive errors such as Unexpected decimal point calculation
Illegal floating decimal point calculation order
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and try open the video.
Or try to convert the audio to wav before converting(If you have problems extracting the audio using Virtualdub try use Goldwave or AVI2WAV).
Or try to repair the AVI,DivX or the ASF.
Or try to use avidefreezer to fix your video source.
https://www.videohelp.com/tmpgenc.htm#problems
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 20:30 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
