Virtual Dub to avi no compression, then convert, then burn?
based on the high level limited information yes. The devil is in the details...
@ vitamine..
after re-reading your question 4+ times, YES.
I understand your question, and it does make sense.
Capturing in any app ie, vdub or avi_io etc., and choising NO type of
compression IS about the highest form of quality you can get in your
given capture.
You don't really want to do rea-time MPEG capturing IF you are REALLY
adimate about quality. MPEG, no matter how you slice'n dice it, is still
compressing your capture source, but on the fly. And, as a result, something
MUST give.
Real-time capturing is good for those who are NOT strapped for quality,
and/or low on budget and or are newbies and or need quick turn-around
w/ their projects. Comprimises are made daily. What works (or used to)
work today, may not, tomorrow.. from person to person. It all depneds
on each individual.
Quality..
Other issues of quality might be the:
* source quality (cable vs. satellite)
* capture card
* capture card chip-set
* codecs used
* onboard codec/hardware etc.
* cables and wires used to connect these gizmos
* capture settings ie, resoluiton, codecs, bitrate etc, etc.
Hope that helped some.
-vhelp
Help Finding A High Quality Capture Card
By NMeade in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 21:00 -
Need new ideas to Capture Video game footage at high quality
By APFable in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 20:27 -
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 17:39 -
how to capture in very high quality in VirtualDubMod?
By ayyak in forum Capturing and VCRReplies: 5Last Post: 5th Jan 2009, 03:41 -
Seek High Quality Capture to MPEG4 Service Provider!
By bradeso in forum RestorationReplies: 3Last Post: 25th Aug 2008, 12:59
