okay i just got this mpeg file and tried to burn with nero 5.5, it then told me it was an incompatible video stream. I then went to the help pages on this website and downloaded all the programs needed to fix. First i renamed the the file do .dat and used vcdgear to make a new mpeg file. After that suprisingly worked, i tried to burn the new mpeg file with nero and got the same message (i think).
then i used mpegprop to check if it was a complaint vcd mpeg and i was confirmed that it was. So then i tried to encode the file using tmpgenc and i couldn't even open the file, it gave me the error messgae of incompatible formart or somethin like that. So for all you pro's out there (obviously not me) can you tell me why the hell i would have a file that it supposed to be vcd compliant yet i can't burn that bastard
oh and i also can't use windows medai player to play it, it says "no combination filters can be found to render this stram"
