I use PowerDVD to watch DVD's on my computer. I had an ISO file and wanted to watch it on the PowerDVD. So I selected the ISO file, and the PowerDVD stated "Play". But no movie came up...
Does anyone know how to remedy this?
Thanks.
If everything is infinite then nothing is definite.
You need to mount the iso on a virtual drive like Virtual Daemon. You can download it from the tools section.
Regards,
Rob -
or simply right click on the file/open with..media player, it works for me with most files, just make sure you have the right codecs, hope this helps
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Problems Playing Bluray ISO in PowerDVD 8
By aye29 in forum Software PlayingReplies: 5Last Post: 4th Sep 2008, 20:28 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01
