hi there,
i totally new to premiere and i wanted to capture my video data from the dv-cam to the pc. but i have no clue what options i have to chose with premiere. its just a holiday video and i wanna encode it later to svcd. so quality is a term but hasnt has to be dvd quality. it should be just right without any dropped frames. so can somebody help me.just a short description would be appreciated!!!
thx
tommybs
kazaa rules...
tommybs,
This book will tell you just about everything in Premiere you need to know..
http://www.wileyeurope.com/WileyCDA/WileyTitle/productCd-0764536648.html
Of course you can use Premiere's built in help or you can go to the Adobe website and use the forums there. But be warned if you post an extremely general question like this, you more then likely will not get much of an answer, other then please read the help file first. The book in the weblink is something I still use alot well worth the money. But in a nutshell, You need to hook your camera up to the computer via firewire, open Premiere, and use the file menu, Capture, Movie capture... If your camera does not have a firewire port, well then you'll need to look into some form of capture card, then watch how much youll need this site! Good luck! BTW, if you got the Premiere off something like Kazza, it's most likely a butchered edition that will end up giving you problems.
Capture on FCP, edit on Premiere
By benchaz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 28th Nov 2008, 11:34 -
HD Capture questions w/ Premiere pro
By miamibluemoon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 27th Feb 2008, 02:38 -
Premiere - how do I change capture format?
By djbryson in forum Capturing and VCRReplies: 15Last Post: 17th Nov 2007, 10:42 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 15:24 -
SVHS Capture / Premiere Pro 2
By tokyomaskproductions in forum Capturing and VCRReplies: 4Last Post: 16th May 2007, 14:48
