lately i have been getting in Recordnow DX, the error: Terminated with errors duing burning a VIDEO_TS folder generated by DVD2One. The only thing i changed was setting in DVD2one from 4200 mb to 4400 MB for the copy. Recordnow also shows around this size for the VIDEO_TS Folder. An it also allows to burn this folder...But the strangest part is that all the DVD's work perfect, even the ones which get this error. Is this a bug with Recordnow DX ??
I usally set DVD2One at 4472 mb using Samsung Beall discs.
It may be a problem with your blank DVD's as some will / cannot burn to their full 4.3gb.
What discs are you using, as it looks like every thing else is done ok.
Off topic but sorta relative, if useing DVD decrypter in file mode the film comes out less than 4472mb, why wont Record Now max burn it. As I have to then run it through DVD2One and hence loose a little bit more quality. It was a 2 layered disc but just the film comes out at under a blank DVD-r size. Help ?
Regards,
Fatboy -
i use creation dvd-r's they are supposed to be 2X but to be sure i only burn at 1X.
Another thing: In Recordnow DX when you go in the options screen you see under DVD: "not closed" I only realized that yesterday that i have been revcording without closing the DVD. But the DVD's all play in my standalone DVD Player ?? The default seems to be 'not closed" Can I Change this ??. -
For max compatability with dvd player in the options section, under DVD always set disk to closed.
Also start by selecting DATA then under mulitsession (new volume) and in volume label only letters or numbers(no spaces if spliting a name use the _ ) then go to options and close your DVD disc. And yes find your film with (find files or folders). Dont forget to include a empty AUDIO_TS folder with your VIDEO_TS folder for max compatability.
Hope it helps
Fatboy -
thanks fatboy for your info.
But even after doing all you said. I Still get a error (at the end of the burning process):"Terminated with errors"
I Will try the same with the DVD+RW (I own the Sony DRU-500AX)
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
