I just got the matrix reloaded on 3 SVCD's and i want to convert it to DVD complinant MPEG2 so i can author a DVD with spruceup. I have done this before with lord of the rings 2 towers with no problems.
My problem is this: i can get the audio to work! I cant open the .mpg file in VirtualDub (gives me this error: MPEG Import Filter: pack synchronization error) and i cant open it in TMPGEnc in the audio slot (it says 'File "C:\cd1.mpg" can not open, or unsupported.') but i can open the same .mpg in the video slot and even encode and it looks great, but no sound!
I know the .mpg itsself is fine cause it plays perfecty with PowerDVD. I tryed importing the .mpg's directlty into spruceup but it says its incompatible.
And i have the Nimo codec pak installed as well.
Please help ASAP!!
TIA!
Closed Thread
Before you reply, please observe our following forum rules
Do NOT give warez.
Do NOT link to warez .
Do NOT ask for warez.
Do NOT provide information how to obtain warez.
Do NOT advocate warez.His name was MackemX
Warez
Intellectual property (IP) that is distributed illegally. Examples are software being given away or resold without the permission of the author, serial numbers or ways to crack software that is sold (serialz or crackz), movies, music, etc.His name was MackemX
well whatever, your just jelous.
i got it to work, i dont know why this worked but it did:
opened MPEG tools in TMPGEnc and opend the orgional .mpg file in simple multiplex tab in video input field. hit run and it made a audio only .mpg file, now that file works as a audio input in main project. did a short test (3 mintes) and it worked fine, audio all there and in sync.
Jerome187 in future please obide by the forum rules and read the definition of warez.
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17
