  1. is this for the us or uk model?
  2. I'm afraid you have to start testing CD-RWs instead of CD-Rs. I have one of these ( I'll assume UK model as I'm in Australia ) and it works with some CR-RWs. ( At least it does when it's in the mood )
    So far I have found JNL( 50/50 bet ), Avalon(8 out of 10 work) and Traxdata( about 40% work ) to be okay. If anyone has any better bets, please add them in. I can use the info too.
    Regards,
    Ian
    Jun 2001
    Mr CDR
    Try Mr. Write CD-RW. It works best. You can order online from http://www.computer123.com at $3.50/10 pcs. Browse:Media, Brand: Friendly CD Tek.
  4. where can i buy avalon or jnl cdrw's (store or website)
  5. I haven't seen the JNLs locally for a while ( I'm in Melbourne, Australia so you may have trouble if you're not. Sorry ) and the Avalons can be obtained at Jaycar Electronics. Don't know if they have a web site.
    Good Luck
    Ian
  6. I have the exact same DVD player. Use Memorex CD-RW 4x-10x and it works perfectly.
  7. i have memorex 1x-4x and they dont work, do you think i would get better results if i used 4x-10x?
