Hi for all!! Congratulations for the excelent site!!!!!
I've a movie (captured from TV) that has rolling bar (in the footer) with msg from the viewer.
My question is: how can i hide or remove this rolling bar from the movie without losing quality (sound and image).
Thanks!!
the easiest way would be to crop it out. You'll lose a portion of the video, but it's underneath the footer anyway...
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Hi there
Unless I'm missing something you are going to have to re-encode your video after cropping it.
What format is the clip at present ? Is it an mpeg or avi file or something else ?
You will probably be ok as far as audio quality is concerned since you can extract the sound as it is now but one way or another, (unless you are going from uncompressed avi -> uncompressed avi) you probably will loose a little video quality, how much depends on the current format and which format you want the edited clip to be in
Cheers
Edz
How to hide something with Sony Vegas Movie Studio?
By sdsumike619 in forum EditingReplies: 8Last Post: 14th Jan 2012, 17:09 -
Best software for Frame by Frame Video Edit?
By VEBouto in forum Newbie / General discussionsReplies: 5Last Post: 8th Feb 2010, 16:28 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 14:39
