    Jul 2002
    Scotland
    Hi,
    Need some help converting a xvid avi to (s)vcd.
    I have a avi file download which when I run through TMPG will freeze at the same point everytime. The preview stops but the process continues.
    When I play the file the video will fress and the audio continues.
    I have used divfix to re-build the index and cut out bad frames -no joy.
    I have decompressed the avi, the file freezes - no joy
    I have scanned with virtual dub and saved avi the file freezes - no joy
    I have used AVI2SVCD, guess what, - no joy. The process stops at the audio extraction.
    I have extracted the audio with virtual dub and re-encode with TMPG -no joy
    Is there anyway to repair this file or is it a lost cause
    Thanks.
    dlb.
  2. Do I gather from your post that your problems always occur at frame #8211?
    Apr 2003
    my computer, where else?
    what's the audio?
    which vdub version are you using?
    if it's ac3, install Odio Dekoda
    http://www.moonlight.co.il/download/?dl=odiodekoda
    try using vdub mp3 freeze (available in tools section) to scan for and delete bad frames
    after deleting bad frames and saving as avi, load the avi file in tmpgenc
    and use it for both audio and video. has worked well for me since installing Odio Dekoda
