Hi guys 'n gals i have a big problem and its driving me mad![]()
I keep getting "The error occurred when acm was initialized" error when i try to encode Xvid/ac3 movie![]()
Ive changed the priority settings correctly having read about here but it still wont encode.
Please can anyone help,it is really annoying me now.
Thanks all![]()
does the movie play on your computer?
The weired thing is on my computer xvids play without and playing with the settings. The only things set other that 0 are directshow multimedia reader -1, avi vfw compatibility reader -2.
you might want to try a different xvid codec. I had problems with a couple until i found one that worked good.
Tmpg doesnt like ac3 very much. If you want to convert it. Follow this guide:
https://www.videohelp.com/forum/userguides/91588.php -
Thanks for the replyOriginally Posted by Pugsly456
Firstly yes it plays in all my mediaplayers fine(wmp9/zoomplayer)
all my settings are set up ok in TMPGEnc .
Tried saving out the audio to .wave then putting it thru headache to convert but i get a error in headache aswell
Ive got a Xvid codec installed that seems to play Xvids but when it comes to encoding using TMPGEnc i get ACM error
Surely theres a way round this.
Anyone? -
use Odio Dekoda, solves all your ac3 problems
http://www.moonlight.co.il/download/?dl=odiodekoda -
Ive already got that codec installed according to G-Spot.Originally Posted by honorarybrutha
Anyways, good news ive managed to encode it now
I did have to get the movie again tho and then converted to .wav using headac3e and hey presto it works now
Cheers for the help tho,much appreciated
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 22:30 -
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
Megui vob to x264 giving some error in log........help plz
By crb119 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2009, 18:15 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 27th Jul 2007, 00:05 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 18:52
