Hi,
Is the sound created for a DVD by a programmes such DVD Workshop, MainConcept or TMPGEnc a different format than that on a commercial DVD?
Take care
Dave
Dave Knowles Films
Southampton - UK -
Most Commercial DVD's use Dolby Digital, DTS or in rare occations PCM. MPEG audio i also used in europe in some cases. So to answer your question, yes and no. I assume TMPGEnc uses MPEG audio, so that's a standard in Europe, but not in North America.
AFAIK, the DVD standard requires ALL DVD players to support PCM (uncompressed) audio at 48khz sampling. In NTSC areas Dolby Ac3 support is also required but in PAL areas MP2 is required instead.
All Consumer level DVD authoring programs support PCM and many support mp2. AC3 creation is generally only supported by higher end authoring programs due to high licensing fees for the dolby encoder. Many consumer level apps will import Ac3 created externally.
Hope this helps -
Hi,
When I make a DVD using DVD Workshop and try and make a VCD in Eazy VCD the sound shows as "1. ??? (MPEG1 2ch, 0xC0) [0]" but if I put in a commercial DVD I get "VTS(01)PRG(0)02.31.17.15(907715)" etc. Could this be the reason for my VCD's made with Eazy being out of sync?Take care
Dave
Dave Knowles Films
Southampton - UK -
VCDs and DVDs are NOT the same thing. See the what is section to the left for more info. Basically a VCD uses MPEG1 layer II 224kbit/s 44.1khz audio. While DVDs use AC3 (or PCM) 384kbit/s (acutally several bitrates are used) 48khz audio.
You can't directly compare the two. The main reason for sync issues in VCDs are:
1) VCD was made from a DivX/xvid source which had VBR mp3 audio stream.
2) Framerate errors during encode
3) Source is from a DVD rip with an audio delay file -
Hi,
How can I check if the source is from a DVD rip with an audio delay file?
Is there any way to make sure it is in sync?
The programme Eazy VCD does everthing automatically and other people do not seem to have problems.
Eazy VCD is saying that the DVD sound is "1. ??? (MPEG1 2ch, 0xC0) [0]" so I presume that the authoring programme is recording the wrong sound. Would this create problems with playback then?Take care
Dave
Dave Knowles Films
Southampton - UK
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 14:38 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
