I'm trying to convert a DVD to SVCD but I get this error:
Encoding started on Thu May 29 09:21:49 CEST 2003
usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No accelerated IMDCT transform found
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 4294967256 bytes
INFO: slots/frame = 731
INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: Fractional number of slots, padding required
INFO: System is big endian
442 frames in 14.51 sec (30.46 fps), 32 last 1.25 sec (25.60 fps)
The .m2v file isn't created but the .mp2 file is! I did install the 3 external "programs" needed for ffmpegX. The file I'm trying to convert is located on another partition than where ffmpegX (and the system OS X) is located. I also have ffmpegX on the same partition as the file I'm trying to convert but I get the same problem. I'm using ffmpegX 0.0.6m... BUT when using 0.0.4g it all works fine! But for some reason the quality is less and I want to encode subtitles as well (I believe that is possible with SVCD?)... Can anyone please help me!!
AnonymousGuest
AnonymousGuest
I found out that I need a quicktime component if I want to use QT decode... wich i dont have.. but when I use mplayer decode it won't work either!!
Encoding started on Thu May 29 09:52:05 CEST 2003
-f 5 -b 1727 -q 6 -B 260 -V 230 -a 2
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
**ERROR: [mpeg2enc] Unable to open: LCD/SNATCH/snatch_svcd.mpv:
No such file or directory
Using GNU internationalization
Original domain: messages
Original dirname: /usr/local/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MPlayer dev-CVS-030316-14:10-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
Reading config file /Users/arthur/.mplayer/config
Reading /Users/arthur/.mplayer/codecs.conf: can't open '/Users/arthur/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Volumes/Data' 'LCD/SNATCH/TITLE01-ANGLE1.VOB' '-aid' '128'
get_path('font/font.desc') -> '/Users/arthur/.mplayer/font/font.desc'
font: can't open file: /Users/arthur/.mplayer/font/font.desc
font: can't open file: /usr/local/share/mplayer/font/font.desc
Using Unoptimized OnScreenDisplay
Using usleep() timing
get_path('input.conf') -> '/Users/arthur/.mplayer/input.conf'
Can't open input config file /Users/arthur/.mplayer/input.conf : No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
get_path('Data.conf') -> '/Users/arthur/.mplayer/Data.conf'
Playing /Volumes/Data
Not an URL!
File not found: '/Volumes/Data'
get_path('TITLE01-ANGLE1.VOB.conf') -> '/Users/arthur/.mplayer/TITLE01-ANGLE1.VOB.conf'
Playing LCD/SNATCH/TITLE01-ANGLE1.VOB
Not an URL!
File not found: 'LCD/SNATCH/TITLE01-ANGLE1.VOB'
Exiting... (End of file)
And I also don't understand why it does work in the older ffmpegX version...
AnonymousGuest
Okey.. I solved my problem
the problem turned out to be I had a space in my disk name...
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 16:38
