Hello!
I am have a problem that has me highly confused. My Magnvox MDV450 will play DVD+RW's that I have burned, but will not play DVD+R's that I burn. My burner is a Memorex DVDRW 2.4x8AA, with the firmware upgraded to 1.51. Media used is the Memorex DVD+RW that came with the drive, the Memorex DVD+R that came with the drive, and Verbatim Datalife Plus DVD+R disks, the one made in Singapore.
What happens with the DVD+R's is I put them in the DVD player, it says 'Disk Loading', then says disk error after about 20-30 seconds. I have occasionally had the Memorex DVD+R one work, but only for about half an hour before the movie freezing, and getting the disk error message.
I have used a lot of the hints on the forums and guides here, including turning off every option in Nero except ISO standards, making sure UDF 1.02 is selected, used UDF, UDF/ISO, etc., used Bitchanger to make sure it would write in the DVD-ROM part, tried Copy2DVD, Imgtool, DVD Decrypter, etc. in trying to get one of these DVD+R disks to work in the player, but now I have a nice stack of 8 expensive coasters.
I bought a single Nashua brand DVD+R tonight at Wal-Mart I'm going to try, but before I do, I thought I would see if any of you experianced people could help a newbie like me.
Thanks for your time!
Eric
Go to http://www.dvdplusrw.org/ and check if your player is listed as being able to play DVD+R. I've also read somewhere that DVD+RWs are more compatible than DVD+Rs because they have higher reflectivity.
Here's your player:
https://www.videohelp.com/dvdplayers.php?DVDname=Magnvox+MDV450+&Search=SearchGeronimo
RETAIL DVD plays in standalone - "No Disc Inserted" message in PC
By prattitude in forum Software PlayingReplies: 6Last Post: 28th Nov 2007, 12:07 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 17:25 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 11:07 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 21:15
