Hi there,
I know that a RAID-0 array increases the drive's speed, thus reducing the dropped frames while capturing. I have one question however : How does the on-board RAID controller in Abit KH7II perform, compared to those ATA 100 Raid controllers by Promise ?
Thx in advance.
In theory, all other things - BIOS, drivers, etc. - being equal, the on-board HPT-370 RAID controller on the ABIT board should perform similarly to the add-on RAID cards that also use the HPT-370 ASIC, like the Iwill SIDE-RAID 100. Storage Review did a benchmark putting the SIDE-RAID 100 up against the Adaptec 1200A card, which also uses the HPT-370 ASIC, but uses different BIOSes and drivers. They also included data for both the AMI MegaRAID IDE-100 and the Promise FastTrak 100.
The SIDE-RAID 100 generally performed on par to all but the Adaptec card, which trailed the pack by 1-3%, in RAID 0 as far as transfer rates. But not in tests like WinBench's Business Disk or High-End Disk WinMarks - though there is some debate that these tests are dated and/or that manufacturers can customize drivers and firmware to perform well on these tests.
You can read the whole review here StorageReview.com.
Based on these data from SR, I wouldn't think that buying an add-on card would be justified. Of course, after the HPT-366 debacle on my ABIT BP-6 ultimately got swept under the rug, when I hear "High Point Tech", I head for the hills...
Just G
<font size=-1>[ This Message was edited by: Just G on 2001-09-21 08:13:18 ]</font>
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 05:13 -
Raid 5 to Raid 1
By mysts in forum ComputerReplies: 4Last Post: 14th Mar 2009, 00:36 -
1TB Raid?
By CogoSWSDS in forum ComputerReplies: 8Last Post: 30th Sep 2008, 09:35 -
Is Raid 1 always this slow?
By gary11364 in forum ComputerReplies: 7Last Post: 5th Aug 2008, 22:23 -
Using Raid 0 for Rendering?
By jaffacaique in forum EditingReplies: 7Last Post: 3rd Aug 2008, 19:32
