Problem:
convert a PAL 5.1 AC3 DVD to NTSC 5.1 AC3 DVD
I did my homework and could not find products (until now) that would accept AC3 5.1 or wouldn't down convert it to 2 channels AC3.
Solution:
DVD Decrypter to get your DVD to hard-disk.
DVD2AVI (Demux all tracks to AC3)
TMPGenc (set parameters for DVD to convert to PAL, then load unlock, and set to ES Video only).
DVD-Lab import the m2v file generated by TMPGenc and the AC3 file generated by DVD2AVI. Cut your DVD (may be IfoEdit to check it, if you don't trust me).
If your DVD is a DVD-9, some more work needs to be done, documented elsewhere on this site.
Conclusion:
I own Ulead, and made the big mistake to buy the AC3 PowerPack ($199). Useless, as it downconverts to two channels stereo. When I sent an e-email to technical support I got an arrogant response pointing me to the specs in Ulead Web page. I did my homework and tried some free products (e.g. ReMpeg,..). None can do it, except may be the open source FFmpeg, after some enhancements. Working in software development I don't want to spend time on it. DVD-Lab is $99, and that's the only product that I found that can do it. Don't buy the AC3 Powerpack unless you got a real need.
Last, DVD-Lab is slow in muxing (and I got a 2.8G processor), but it does the job, so its worth it.
Results 1 to 1 of 1
Sony Hi8 (PAL) pass-through to Canon (NTSC) - will this work?
By frappefan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Dec 2010, 13:18 -
will a NTSC sony FX1 work in australia were we use PAL?
By gogofilms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2009, 17:57 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Would a Digital Video Stabilizer work for a PAL tape in an NTSC vcr?
By ChaunceyK in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2007, 12:42 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 16:22
