I have been trying to convert this DvD rip from Avi to MPEG so I can make a vcd out of it. However, after converting the audio is very out of sync with the picture. This only happens when I try to convert certain movies. Some movies come out perfectly fine...others do not. Some of my movies only have a few seconds of audio at the beginning of the movie after they are converted. Anyone have any suggestions on what I can do or what my problem may be? Any help is appreciated!![]()
Do you scan and remove bad frames first?
Do you strip the audio into a wav file and use that as your audio source?
You should be doing both of these."Art is making something out of nothing and selling it." - Frank Zappa -
if the audio is ac3, install Odio Dekoda
http://www.moonlight.co.il/download/?dl=odiodekoda
converting mkv to avi + problems
By sgbd in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 13:53 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17
