Results 1 to 13 of 13
    Portland OR/Hita Japan
    I have an MP3 and an AVI file encoded from mediapipe. And I need them o be ogeher in one avi file. Is there a program or a way o put them together? Quicktime wont work, since it saves i as an .mov formated file.
    Q
    "Good Luck 007"
    In Memory of Desmond Llewelyn
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    FFMPEGX Under Tools, there is a muxing option
    quicktime will work. It will mux files. And, I could be wrong since I have not done this ever, I believe Quicktime has divx export?!?! Correct me if im wrong but isnt the Gershwin or DiVX codex thats out now got a quicktime divx export?
    check www.divx.com for more details.
    hope that heps ya
    Its already a Divx File, why would I have to reencode it?
    hrmm ill try ff
    thanks
    Q
    "Good Luck 007"
  4. Member galactica's Avatar
    Jan 2003
    hrmm ill try ff
    Q
    Not sure what you mean Reencode? The tools option and the muxing is not a encoding portion of FFMPEGX. You are goign to select your VIDEO FILE (may have to rename to .mov for this purpose) then select your AUDIO FILE, and choose the MUXING type and press GO not ENCODE
    hope thats clear
    i kno, im not retarded. Quickime, why would i have to reencode it with the divx encoder?
    ffmpeg doesnt work directly with an avi. ill rename it and try.
    Q
    "Good Luck 007"
  6. Member galactica's Avatar
    Jan 2003
    renaming it to .mov should allow it to work. Let me know....
    i found a thing called AVItool. it muxes mp3 and avi to get a resulting working .avi
    Q
    "Good Luck 007"
  8. Member galactica's Avatar
    Jan 2003
    Can you supply your source for this tool. I checked both versiontracker and macupdate for it and they dont have it.
    I could look around more, but if its not on these two i usually dont
    thanks
    mediapipe.sourceforge.net
    scroll down to news, and you will see a link
    Q
    "Good Luck 007"
  10. I did it using ffmpeg and its passthrough option for video and "add audio". Worked without problems as well.
    but it wont work with my Archos jukebox Multimedia if i use that method
    Q
    "Good Luck 007"
  12. Member galactica's Avatar
    Jan 2003
    Interesting, Ive had no problems with the muxed .avi's from ffmpegx playing on a pc. I would think that if they work on PC they shoudl work with the Archos jukebox Multimedia.
    Oh well.
    The point is, you found out exactly what you need to do!
    yup yup
    Q
    "Good Luck 007"
