hey,
i encoded a svcd with sefy's template for sxvcd (baasically his template for svcd) the file was a little too big to fit on one cd, soi wantto cut the end of the movie off a bit.
now, when i go into tmpgenc 12h i go to mpeg tools, i go to merge/cut add the file as a svcd and sava my output file.
when i go to edit the file to cut it, it wot show the video!
so i cant tell where to cut it. and even if i wantd to so by time, the [ and ] wont even higlight!
all i can do is hit play or pause, and the forward and
rewind buttons. i also tried downloading tmpgenc 12f and it didnt help as i had the same problems
please can anyone help?
thanks-
Results 1 to 15 of 15
There is a way to do it with tmpgenc but an easier
way is to use a proggy called avi2mpg2 which is
quite easy to use. firstly demux your mpg movie file
with tmpgenc, load avi2mpg2 and set it up to cut the
file into how many cd's you want ie 730 mb the file will be split into 3 to fit 650 cd 74 (mins) or 790 it will split the file for 700 mb cd's (80min)
if you cant understand this waffle, then go to dvdrip.ws
and go to cutting svcd's you will get a full explanation there, if you want I can email you the instructions -
As you said you couldn't see the clip you wanted to cut in TMPGEnc Mpeg Tools merge/cut. If this happens (screen greyish) then your mpeg stream is somehow corrupted. Try downloading from the tools section of this website the mpeg corrector and run the mpeg file through there. After that try again with TMPGEnc. Another thing that may work is that you run the whole file through the "merge/cut" process without any start and end markers. Don't forget however to determine your output type at the top.
thanks for the quick reply
i dont understand how my file could be corrupted, asi did it exactly as the guide here said to.
i went ahead and re-encoded it but left some off the end.
this made the file about 785 mb.
now nero wont burn it at all. i was able to burn vcds in nero fine, now it just gives me a scsi/cd error and says that burn process failed at any speed i try, before the burn can even start. maybe i should upgrade my version of nero? i cant understand this. why are svcds more of a hassle when vcds worked out fine?
i cant even get ez cd creator 5 platnum to burn a data cd
it just freezes up.
any advice would help me out!!!
thanks- -
If you're running EZ CD Creator and Nero on the same system, then that's your problem. Choose one burning program and stay with it.
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-07 15:58:23 ]</font> -
ok
but could you explain why?
i just use ezcd for mp3s but i can live without it.
is nero just picky?
thanks again- -
It's actually EZ CD Creator that's fussy, or let's call it egoistic and the reason has to do with the ASPI drivers. There is a program you can download from the nero.com website that at the bootup of your system, you can decide what to install - I personally couldn't get this program to work for me - you might be luckier?
Regarding your mp3's - you could of course get the mp3 plugin for Nero - but of course it cost's money. Or you get free software to convert your mp3's into wav's before taking them into Nero.
Alternatively you could of course keep EZ CD Creator
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-07 16:15:22 ]</font> -
ok i uninstalled ezcd creator and tried again.
still i get the errors.
they are in this order
scsi/ide error
invalid writestate
could not perform end track
current program area is empty
could not perform fixation.
=P man i dont get it.
maybe ill have to reinstall the newest version of nero? -
Just uninstalling EZ Creator will not help. You have to reinstall Nero. What version are you using?
http://www.nero.com/mpeg2time.htm
why would it say that when scvd is already an option?????? -
The MPEG2 plugin for Nero is for those who don't use other software to convert their avi's, mpeg's etc. to the SVCD specifications. I wouldn't worry about this!
well im just gonna upgrade to 5.5 and hope for the best
i dont know what else to do.
and nero is all that will burn svcds so i guess im screwed if it doesnt work. -
that did it!
i upgraded to 5.5
and all is well, i reccomend 5.5
as it has some cool features.
thanks for the help guys-
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
