Hi There,
I have been using the Hauppauge DEC2000 freeview box to do DVD captures. Basically it is a normal set top box with a USB output to connect with the PC. You can use the capture program to make what I am told are DVD compliant captures.
Indeed I checked them in Virtual Dub and all seemed right. The video and audio settings looked fine. However I have been trying out TMPGEnc DVD Author program with a view to investing in a DVD Writer. It said that the files created by the DEC2000 were not compatible with MPEG 1 or 2. I'm sure this is incorrect but was a bit concerned. It seemed to have no such problem with a capture made from my Provideo PV-256 - a card that seems to specialise in non-standard captures.
I was therefore wondering if there is any program that will thoroughly analyse the file and let me know if it is compatible with the DVD standard.
Samsung BD-P3600 DVD+R compatibility
By ynoldus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Oct 2009, 14:55 -
DVD burner compatibility with Dell
By LWC in forum ComputerReplies: 14Last Post: 29th Nov 2008, 08:17 -
Check for DVD-compatibility
By otternase in forum Video ConversionReplies: 1Last Post: 29th Aug 2008, 03:58 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 21:17 -
Increasing DVD playback compatibility
By Truelight54 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 17:51
