Hello,
I have a movie that is on my hard drive, in the VIDEO_TS directory, with > than 4.3G of .VOB files. It is not encrypted and I don't mind putting it on two disks. Can I simply burn half of the .VOBs onto one disk (in the VIDEO_TS directory), and do the same with the other half onto disc 2, and expect it to play on the set top, or do I have to actually do some thinking & edit the IFO file? The .VOBs will play individually on the computer.
Thanks in advance for your time, I'm new to this.
-Steve G
you can use vobedit and ifoedit to edit your files and then rebuild a new ifo file for each disc if you want....... but im sure there maybe easier ways to do it :P
Ifoedit .95 has a split to two DVD function. It will automatically slpit the DVD into two directories with separate VIDEO_TS directories for you.
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01 -
Question for .Bup & .Ifo files..
By Pleochoric in forum Authoring (DVD)Replies: 4Last Post: 31st Oct 2008, 05:33 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
