Hi, everybody.
For some odd problem, I can't use CDRWin (demo version), so, knowing that Nero doesn't respect the cue-sheet at 100% (I heard of problems on the VCDImager mailing list), i thought to mount the Cue with daemon-tools and then doing a CDCopy.
Can this bring me any problems? The Daemon-tools are 100% Cue-sheet compliant?
Thank you.
MarioB79
The Daemon tools can mount your bin/cue images properly. I don't see why you can't do a CD-copy this way. Another thing to try is extract the MPEG from the VCD (I suppose the bin/cue image is a VCD) using VCDGear or vcdxrip from the VCDImager software suite.
This MPEG can be dragged into the VCD project of your burner software like Nero.
Maybe this link helps solving your problem:
http://www.vcdhelp.com/burnbin.htm
Regards,
Willem -
Why not try Fireburner? (www.fireburner.com)
If you do, I would recommend v1.06 and v2 seemed to be buggy (at least to me).
Fireburner fully supports bin/cue files.
Fireburner fully supports bin/cue files.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I tried, but I can record only at full speed (16x) and I think it's too much! (It's a demo limit, or my burner not full supported?)
Bye
MarioB79 -
You could try the Win32 build of CDRDAO. There is a good GUI that you can get for it too named "XDuplicator". This works quite well and is fully freeware.
If you search for the above proggies with Google, you will be able to download them.
Regards.
Michael Tam
w: Morsels of Evidence
Video (Not movie or TV) organizer with thumbnail sheets?
By Maoukiji in forum Newbie / General discussionsReplies: 9Last Post: 28th Jul 2013, 15:38 -
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Problem making contact sheets from vids
By majax79 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2008, 17:26 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 12:29
