    Mar 2002
    Ireland, Republic of
    Sorry if this has been asked before, but is it possible to play background music on a VCD menu? I author with NERO.
    Thanks!
  2. Member adam's Avatar
    Sep 2000
    This is not possible with Nero. There are several ways to make motion menu's as well as add audio to still menu's in a VCD or SVCD. If you look in the AUTHOR link to your left you will find the relevant guides.
    Jan 2003
    Nassau, Bahamas
    you can properly author it with music and a background image using ulead dvd movie factory,...dont worry, its very easy
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Mar 2002
    Thanks for the replies guys. I will check out the authoring guides and Movie Factory.
