Just tried to make my first DVD backup of The Transporter Region 1 but i've run into a problem.
Its a DVD-5 disc so i read that the best and easiest way to do this was with DVD Decrypter. So i read the instructions on this site and extracted the disc as an .ISO. But in the same folder was another file with the same name but with a .MDS extention. The guide made no mention of this.
Anyway I carried on the burnt the .ISO to DVD. Half and hour later the program said the burn was successful, but the end result was a disc that won' t play.
I check the DVD the only file on there is a VIDEO_TS file with all the .VOB .IFO and .BUP.
Using DVD Decrypt v3.1.6.0
Anyone else have any problems? Anyone know what i've done wrong?
Oh yeah it comes up with a 'This disc is not formatted to play in this region'. Message comes up on both a region free PC DVD-ROM & standalone R/F Toshiba 220E.
Just tried playing the .VOB file directly from the disc via PowerDVD and they work. So it looks like a region protection thing.
Any ideas?
Thx
BananaSkin
let me guess -
you're using Win98 or WinME, and your hard drive is formatted for FAT32.
So you have a 4Gb limit on file size.
I have used DVD Decrypter with no probs on a FAT 32 drive, you should end up with 3 files:
.iso
.mds
.dvd
When you select the file to burn the disc, don't select the .iso file, select the .dvd file instead.
You should be okay.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
No using WinXP SP1 NTFS
Where does this .dvd file come into it? The guide doesn't mention that.
Thx
BananaSKin -
hmmmm...
I don't think the guide mentions the .dvd file because in theory, you can't use .iso mode on non-NTFS drives.
Did you get a .dvd file when you ripped the disc?
If not, this is a new one on me....- housepig
Housepig Records
out now:
Originally Posted by BananaSkin
Just doing some tidying up. This came from the other thread.
BananaSkin, if you accidentally post in the wrong forum let a moderator know so they can move it, or just wait for one of us to move it. Creating a second thread just splits the discussion up and makes everything confusing. -
Hi Housepig
Just ripped disc again and no .dvd file is produced only the .mds and .iso
Anyone else have problems with DVD Decrypter?
BananaSkin
DVD Decrypter Problem
By WuPhilly in forum Newbie / General discussionsReplies: 14Last Post: 17th May 2008, 16:28 -
STRANGEST problem getting VOB errors on DVD Decrypter, IsoBuster, etc.
By Corellian Corvette in forum DVD RippingReplies: 7Last Post: 16th Feb 2008, 19:52 -
Problem with DVD Decrypter
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2007, 13:01 -
problem with DVDFab Decrypter
By cmonzon in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 20:18 -
Problem burning to Verbatim DVD+R DL with DVD Decrypter
By spyder67 in forum Authoring (DVD)Replies: 6Last Post: 14th May 2007, 17:49
