Ok I downloaded a divx file and when I got play it it plays for about one minute or so and then jsut shuts off all divx without a pop up box sayaing anything, and also when I try to skip that part and clcik somewhere on the play bar it skips to the place freezes and either shuts off the same way as befor e or says that "windowns virtual memory is too low" and then closes, so I got Divfix and scanned it for errors it found like 17 errors or bad frames, is there anyway to cut these out?
there is a setting in divfix that says to automatically fix frames. Not in front of the app right now, so can tell you exactly where it is. Go to guides section of this site and seach for divfix.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 20:07 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
DivFix++ v0.30 won't open
By Bix in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2008, 00:40 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
