I want to convert an rm to avi and then to vcd. What file should i convert it into? I dont want to use divx.
I dont care about quality. I just want it to convert fast. THANKS.
huffyuv is very fast, so is uncompressed..... but why avi to vcd, just go rm to vcd
You win some, and you lose some, and some get rained out... -
you could use something like EO Video to convert the .rm to compressed Huffyuv .avi, then convert the .avi to .mpg with TMPGenc or CCE
I haven't used it that much, but I think that TINRA always works in (pretty much) realtime.
That is to say, even if you go for uncompressed avi output (or huffy etc..), TINRA will take 20mins to process a 20 minute clip, 1hr to do a 1hr clip etc..
It may take longer using high compression (DivX/Xvid etc..), but I don't think there's any way to make it convert in faster than realtime.
Someone please post if this is wrong - as I say, I've only used TINRA a handful of times.
cheers,
mcdruid.
P.S. ryanreko - how do you go straight from rm to mpeg/vcd, missing out the avi step in the middle?
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
