I've two folders on my HD (VIDEO_TS and AUDIO_TS). I want to make an image of this. Which tool do I need?
I don't want to use NERO.....
thx![]()
You can use imgtool
https://www.videohelp.com/forum/userguides/152875.php -
Get version 0.89 of Imgtool, and then use ifoedit to create an image that can be burned with DVDDecrypter.
Hello
Just wanted to point out that there are two versions of ImgTools and the version I have used (with great results) is the "classic version"
I then burn the image with DVD Decrypter.
There is a guide on the doom9 website for using DVD2ONE which gives you a step by step method to using ImgTools (classic version) then DVD Decrypter.
Even if you don't use DVD2ONE the guide will still help you since DVD2ONE creates a VIDEO_TS folder (you have to make the empty AUDIO_TS folder) then you just pick the guide up from there for the ImgTools to DVD Decrypter to Final DVD recordable method. The process is the same no matter what program you used first to get your VIDEO_TS folder and files.
Where can I get the "classic" verion of ImgTools? How would I know if I got the "classic" version? Does it have specific version number?
The current release is ImgTool Classic 0.90 Build 4.Originally Posted by vvrok
You will find it here and then goto the "Download ImgTool" on the left side of the web page:
http://www.coujo.de/
[DVD Architect] Making ISO image (DVD DL)
By Madras in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2012, 15:27 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 20:01 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
