I have been doing this for a while and have learned a lot from this site. Since I upgraded to XP, I am having a problem with vcdeasy. I have read all the forums I could to find my problem.
When open vcd message says no cd writer/reader found or ASPI driver problem. I used force and fixed that no my writer and reader are gray. Why?
Thank you for caring
Chodaro
well. fixed my problem. I have downloaded to xp. When you do that you neet to download and aspi. I downloaded aspi v4.7 and it actually hurt my more than helped me. if you have aspi (adaptec) then all you need is ASPIPOST.SYS and wnaspi32.dll. They say that you do not need WOWPOST.EXE and WINASPI.DLL. Now I do not know if that is true. But,anyway what I did to fix my problem was uninstall aspi (adaptec)4.7 and download aspi(adaptec) v4.6 restarted my computer and boob it worked. Do not know what the hek the difference is but, it worked. Hope I help some people out
here's a good site to visit. radified guide to aspi. It is what helped me
Chodaro
I find that ForceASPI generally works better than the Adaptec installer...
Regards.Michael Tam
w: Morsels of Evidence
ok, I do not know if this is happening because of me changing adaptec 4.7 to 4.6 but, ever since it is giving me files instead of playing on my computer. I know, I know don't be picky,but, it does play on my dvd player. But, ever since I upgraded I've had all these problems!
UPGRADING WAS MY HUSBAND'S IDEA AND HE DOESN'T EVEN USE THE DARN THING!!!
help if you can please
thank you
chodaro
I just use vcdeasy. download,virualdub,tmpgenc,then vcdeasy. It just seams that ever since I downloaded xp it's not working how it use to. Don't get my wrong, It is still working on my home dvd player and that's what really matters to me, but, I just didn't understand why I had to change so much on vcdeasy. I have been making movies for a long time now and I owe it all to the forum and the tech support guy site. I read and read for weeks figured everthing out then it all made sence.
I have a compaq dvd-rom sd-621b
& lg cd-rw-ced8083B
Thanks for all the responses!
Chodaro
Best reader for DVDrs with degredation problem
By Blackout in forum DVD RippingReplies: 30Last Post: 19th Aug 2014, 17:09 -
Blu-ray writer driver
By opticsman in forum Authoring (Blu-ray)Replies: 1Last Post: 30th Jun 2010, 08:52 -
HELP PLEEEEEEZE! Pioneer DVR 111L Writer, Need Driver
By golfnut in forum DVD & Blu-ray WritersReplies: 6Last Post: 18th Feb 2010, 22:09 -
DVD writer/reader...unable to read DVDs
By maass in forum DVD & Blu-ray WritersReplies: 7Last Post: 9th Apr 2009, 12:08 -
HP DVD Writer 300n SCSI CdRom Device Driver Issue
By link2009 in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2008, 17:50
