I am looking for a capture card to replace the Xcapture that I have now. I will be sending video from my Directv Satellite receiver via s-video.
I have several questions to ask.
1) Is this a capture card itself or just a analog to digital convertor? In the manual it stats to connect to the capture card so this is why I am asking.
2) How does this connect to the computer (by USB)?
3) How do you get the audio to capture?
4) Do you have to connect the L/R or will it pick it up thru the computer? Also does it accept or pass thru DD or PCM?
4) What additional software is needed to get a capture?
I have been reading everything I could find out about this but have not been able to get the answers to the above question. I do not mind paying additional $$ if the product will do what I want it to do.
Did you consider going to the Canopus site and looking it up there?
Just throw 3 w's in front and a .com behind and your almost there.
Click the products tab.....digital video converters...okay you can take it from here...everything you want to know about the ADVC 100.
regards
Jim -
Yes I did and that is why I am asking these questions now. The site (i.e) says several times to connect the Canopus ADVC100 to a capture card. I even read the PDF manual.
So will this do captures by itself? -
1) The ADVC-100 is a DV Transcoder that converts to and from DV. It needs to connect to an OHCI Compliant FireWire card like the PYRO card. If you needed to call something a capture card, the ADVC-100 would be the capture card in your setup (technically, you're FireWire card is a simple I/O card and transfers the video rather than capturing it).
2) Everything is captured through FireWire (1394), that's the beauty of DV Transcoder solutions like the ADVC-100 or ADS PYRO AV Link...
3) The audio captures by default...
4) You have to connect the left & right audio, your sound will be DV Encoded and in stereo
2nd 4) Any NLE or simple capture App should be able to handle the DV Stream
Regards,
ADS Ivan
ivan@ADSTech.com -
Thanks for the response. My A7N8X Deluxe MB has firewire, so is this all I need?
I have similar question. I want to get a ADVC100, but I heard that it has compatible issues with some 1394 card using TI's chip. I checked canopus website, but the link does not work.
Anybody has an idea?
what 1394 card do all of you use with ADVC100?
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
canopus advc100 problems--any suggestions?
By esek64 in forum Video ConversionReplies: 3Last Post: 14th Aug 2010, 04:26 -
Canopos ADVC100 doesn't work with Vista 64?
By something random in forum Capturing and VCRReplies: 4Last Post: 23rd Oct 2009, 19:33 -
Fuzzy Video using ADVC100
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 16th Jun 2009, 02:17 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56
