"This one has got me!"
I have a BT848 TV Capture Card in a Intel 1Ghz PC with a Geforce II AGP Video Card and a 7400RPM Hard Disk
Using the Composite Cable from my Sony HI8 camcorder I can constantly capture at 25FPS PAL 384x256 with Minimal Frame Loss of stored video from the HI8 Tape.
Exact same settings, I remove the composite video and audio plugs from the Camcorder and plug them into my VCR and press play of a standard VHS Tape. For some reason I begin to drop about 6 frames per second!!!!
The Hard Disk or processor is not very active so I don't think they are at fault.
Could the signal from the VCR be different from the Camcorder which would cause capture problems??
Any other Ideas?
Results 1 to 1 of 1
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
