I am using heada3he to extract the audio to a wav file from the .a3u file. I followed the guide and am converting to WAV but when I click start it says 'could not load ssrc.dll'. I tried extracting the ssrc-mmx file to the folder but this did not work. Any help is appreciated! Thanks!
chromeman
I found that if you copy all the *.dll that HeadAc3 uses to your System or System 32, as well as having them in the HeadAC3 folder (depending on your O/S0 Folder. It helped. Just a suggestion.
