@FulciLivesI can't speak for your DVD player, but I've studied mine, and I think I know how it is being done:Well I have a stand alone DVD player (the Cyberhome CH-DVD 500) that can play back a PAL DVD and convert it to NTSC and it apparently does it on-the-fly and in a way so that the video matches the original audio.
1. First, every other field is discarded, giving 288 lines of image. This is evident because the vertical resolution of the resulting NTSC image is sub-par. Also, there is no "shimmer" in the result, so the same field information appears to be discarded at all times.
2. The 288 lines are fed through the DVD player's letterbox scaler. This scaler is designed to take 480 or 240 lines and create 360 lines, so it is a 3/4 downscaler (with interpolation for 240 line sources). This turns the 288 lines into 432 lines. This is evident because the resulting NTSC image is slightly squashed and doesn't cover the entire screen, top to bottom.
3. The playback is slowed down from 25 to 23.976 fps. I'm pretty sure about this because there is no "bump" as would be visible if the 25 fps were telecined directly. I also think the time displayed on the front of the player just runs slower. I haven't hand-timed this, but I believe I will find that the actual running time won't match the displayed time.
4. The audio is pitch shifted upward to compensate for the slowdown. The DVD player has karaoke capability and can pitch shift the audio up and down. I believe this is the case because I don't notice any pitch difference from when I play the DVD on the computer. I haven't listened for slightly slower timing, though.You can certainly do the same conversion with AVISynth, with the exception of the audio pitch shift compensation. However, I would prefer not to throw out one field during the conversion. When you throw out the field, you effectively have 25 progressive fps, even if the source was originally interlaced. But if you keep both fields, you have to deal with both possibilities (progressive or interlaced).So if a stand alone DVD player can somehow convert the PAL video to NTSC video to match the original audio ... well ... you would think there would be a software encoding method that could do the same. How do to that though is a mystery to me...
I think the two best approaches for progressive are to slow to 23.976 fps and telecine (with the appropriate audio conversion), or to telecine directly from the 25 fps. It was the latter technique that I was wondering if you'd tried. For interlaced, I think the technique I've posted using a smart deinterlacer works incredibly well.Getting Cinema Craft Basic would probably halve your rendering time for only $58, which is probably cheaper than the hardware upgradeHowever right now I'm running TMPGEnc ... got the bug again ... to convert a PAL movie to NTSC ... so I don't want to run too much at once as this computer is SLOW and TMPGEnc will be running for like another 24 hours or so hehehe. I'm looking at about 37 hours encode time here to convert a 16x9 PAL DVD to a 16x9 NTSC DVD using 2-pass VBR encoding ... I'm way past upgrade time but haven't the money...I guess I'm being pedantic here, but I'm not sure I agree with your assertion. Certainly a cinema film will be sped from 24 to 25 fps when converted to PAL. But there are a number of PAL sources that are natively 25 fps and should not be slowed down. Obviously video, which will more than likely also be interlaced, was shot at 25 fps and shouldn't be slowed down when converting to NTSC. But also, much European footage is shot on film cameras that have been modifed to capture 25 fps on film. Directors object to even the 4% speed change (http://216.239.39.100/search?q=cache:a-7E0W9DUkoJ:www.artistsrights.org/cf/news/detail...ng_en&ie=UTF-8) so this is a technique they've used for direct-to-video, especially for outside shots, before the availability of higher quality portable video cameras. So "a 'true' PAL to NTSC conversion" would take into account the original source. I'm probably quibbling here because I haven't converted a PAL movie to NTSC very often, but I've converted a number of PAL television shows (video) to NTSC (I just LOVE British comedies!).So a "true" PAL to NTSC conversion will restore the original 24fps rate so a PAL DVD with a running time of 115 minutes will be 120 minutes when converted to NTSC...
Xesdeeni
Results 31 to 60 of 229
Hello
Originally Posted by Xesdeeni
The Cyberhome CH-DVD 500 uses a different chip and retains the original aspect ratio when doing the conversion. The JVC and Malata players also retain the OAR although they use a different chip than the Cyberhome (and again not the same as the APEX/DAEWOO/SAMPO units).
I haven't tried your method of converting an interlaced PAL source to 29.97fps NTSC but the trailer to the movie I just converted is interlaced (whereas the movie was progressive) so I might try thta now as I think I will have room left on the DVD-R to include the trailer.
I think my AC-3 is just about done ... over and out!
Xesdeeni, I haven't seen you post in a while... 8)
Just as an fyi, the frame rate conversion in BeSweet does a timestretch. I will compress, or expand your audio to meet the new framerate. It does not speed up, or slow down your audio (ala AssumeFPS in AVISynth). This avoids the change in pitch. It also takes a hit in quality, although I've never noticed it.
Xesdeeni, the Farscape episodes used a 25fps to 29fps conversion. Created a weird telecine pattern, which was somewhat difficult to undo. I'd rather work on telecined 23.976 fps
Sometimes you just have to listed to a PAL, or NTSC file to see if the audio has been timestretched, or slowed down/sped up. As for the true PAL source film, and vice versa, if the authors were that worried about it, they should have shot in both framerates, although that would be expensive. Otherwise, I don't think they have no room to complain if they want their 'art' viewed in NTSC, and PAL land.
As for the conversion techniques. I find the easiest way to verify PAL material (progressive or interlaced), is to save it as a DVD2AVI project file, and open it with an AVISynth script in VirtualDub.
Last but not least, be careful of the aspect ratio reading in DVD2AVI. I've run across many old 'widescreen' versions of old DVD movies that were actually encoded in 4:3 letterboxed, but sold as widescreen. Sometimes you just have to verify that what you see is what you get. Since I've got my widescreen TV, these are a dead giveaway. You can always crop the 4:3 letterboxing off to restore it to true 16:9.Impossible to see the future is. The Dark Side clouds everything... -
Hello
@Xesdeeni
I tried to convert the trailer on the PAL DVD but unlike the movie the trailer appears to be interlaced. So after doing the DVD2AVI thing I created the following AVS script:
Code:# # Created with Gordian Knot # # http://gknot.doom9.org # # PLUGINS LoadPlugin("C:\PROGRA~1\GORDIA~1\mpeg2dec3.dll") LoadPlugin("C:\WINDOWS\SYSTEM\SmoothDeinterlacer.dll") #LoadPlugin("C:\PROGRA~1\GORDIA~1\decomb.dll") #LoadPlugin("C:\PROGRA~1\GORDIA~1\Convolution3d.dll") #LoadPlugin("C:\PROGRA~1\GORDIA~1\FluxSmooth.dll") #LoadPlugin("C:\PROGRA~1\GORDIA~1\TomsMoComp.dll") #LoadPlugin("C:\PROGRA~1\GORDIA~1\VSFilter.dll") #LoadPlugin("C:\PROGRA~1\GORDIA~1\SimpleResize.dll") # # SOURCE mpeg2source("D:\SLEEPLESS\Trailer\movie.d2v") # # CROPPING #crop(0,0,720,576) # SmoothDeinterlace(doublerate=true) LanczosResize(720,480) ConvertFPS(59.94) SeparateFields() SelectEvery(4,1,2) Weave() ConvertToRGB() # # TRIM #trim(startframe,endframe) # # IVTC #Telecide(guide=1).Decimate(5) # or use #IVTC(44,11,95) #GreedyHMA(1,0,4,0,0,0,0,0) # # DEINTERLACING (1) #FieldDeinterlace() #FieldDeinterlace(blend=false) #TomsMoComp(1,5,1) # # DEINTERLACING (2) #SeparateFields().SelectEven() # or maybe #Bob().SelectEven() # or maybe #GreedyHMA(1,0,0,0,0,0,0,0) # # # SUBTITLES #VobSub("FileName") # # RESIZING #LanczosResize(640,464) # # DENOISING: choose one combination (or none) # 1) little noise #Temporalsoften(2,3,3,mode=2,scenechange=6) #mergechroma(blur(1.3)) #FluxSmooth(5,7) # # 2) medium noise #Temporalsoften(3,5,5,mode=2,scenechange=10) #Convolution3d("moviehq") #FluxSmooth(7,7) # # 3) heavy noise #Temporalsoften(4,8,8,mode=2,scenechange=10) #Convolution3d("movielq") #FluxSmooth(10,15) # # BORDERS #AddBorders(left,top,right,bottom) # # COMPRESSIBILITY CHECK # !!!!Snip Size now has to be 14 for use in GKnot! #SelectRangeEvery(280,14) # # FOOL CCEnc #ResampleAudio(44100)
Anyway when I put this in TMPGEnc it recognized it as non-interlaced and as a VGA 1:1 source with FILM based material
Is that correct ???
When I tried to encode it all I got was black for the complete length.
HELP !!! hehehe
ok i have my video file ready. how do i go about with besweetgui to convert the audio?
Originally Posted by ams30gts
First you need to download the newest BETA VERSIONS of BeSweet and the BeSweet GUI which can be found here:
http://dspguru.doom9.net/
You will also need AZID which you can download from the DOWNLOAD section of the DOOM9 website.
I'm no expert at using BeSweet but there is a guide on how to use it on the DOOM9 website. Look for the BeSweet guide on how to do AC-3 to AC-3 which is under the AUDIO section of the GUIDES section. The only thing different you will be doing from the guide is to make sure that you use the PRESET frame rate change of PAL (25fps) ---> NTSC (23.976) and although the guide doesn't mention it there is a place to check if you used DVD2AVI so this should be checked as it helps to correct the delay value (so the new AC-3 audio file has a delay of "0").
Not much to it really
- John "FulciLives" Coleman
P.S.
My encoding of SLEEPLESS (aka NONHOSONNO) from PAL (16x9) to NTSC (16x9) is complete and it turned out super. I think I will be doing more of these ... next up is my PAL DVD of DELLAMORTE DELLAMORE (aka CEMETERY MAN).
*** NOTE FOR Xesdeeni ***
I still could use some help or pointers or some clarity whatever you want to call it on the PAL (interlaced) to NTSC (29.97fps) method as I can't seem to get it working (see my earlier post)."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by FulciLives
I must say that the result looks damn good. I did the trailer to the movie that I encoded earlier however the trailer, unlike the movie, was interlaced (the movie was progressive). So anyways I went ahead and already made my NTSC DVD-R without the trailer but that's ok ... the trailer is very short and sucks anyway.
But the trailer was great for learning the process of converting an interlaced PAL DVD source to NTSC (at 29.97fps)
One thing that surprised me was that the video matches the original audio. THAT is VERY nice. All I had to do was run the program AC3Delay (a very small and free download I got from the DOOM9 website] to correct the -80 delay in the original PAL 2.0 AC-3 file and mux it (using TMPGEnc) with the M2V file that I created with TMPGEnc. Perfect sync and none of that BeSweet garbage.
I'm impressed
However, I am curious about something ...
On your website (@Xesdeeni) I notice that your parameters for the AVS file are (very) slightly different than those given in the *.txt file that came with SmoothDeinterlacer. My first try with your version did not work so I used the version in the *.txt file of the SmoothDeinterlacer documentation and it worked. Then I went back to your version and got it to work just as you had it except I had to drop the line about convert to RGB otherwise I got a blank black screen in TMPGEnc. Is this because I had DVD2AVI set to RGB instead of YUV? Should I be using YUV instead? I just read recently that when using TMPGEnc you will get better results using RGB over YUV when using DVD2AVI. I'm not sure if that comment I read was a speed issue or quality issue or both. I did YUV for the movie and altough it looks very good converted to NTSC (and I am happy with it) I did notice that compared to the original PAL DVD that my conversion was both brighter and slightly less colorfull ... but still more than acceptable (especially after tweaking the contract/brightness and color of the TV I was using).
Anyways now I think I understand what you were talking about before ... I think ... there is a way to convert a progressive PAL source in the same way (using the same AVS script?) so that the video matches the original PAL and therefore requires no funky audio stuff. Right?
OK it's late and I need to be in bed ...
P.S.
I did the clip twice with both your settings and the other settings as in the *.txt file that came with SmoothDeinterlacer ... results? ... both look the same to me except that your clip looked ever-so-slightly sharper (probably the difference in BiCubic vs Lanczos). The image quality in terms of deinterlacing seemed to be the same. Your settings though produced a file of 72.2MB whereas the other settings produced a file of 74.4MB (short trailer) which I thought was interesting since I encoded both with 7000kbps CBR mode in TMPGEnc and both were using the same AC-3 audio track. Perhaps the Bicubic vs Lanczos again?
Cheers!"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
This thread is overfilled with good info
. I highly suggest writing not just a guide on how to do this, but you have alot of info about the differences in general that should be in there somewhere. I might be attempting a project to convert an imported copy of Threads soon, this should hlep alot.
Hello
Hey Xesdeeni
Just wanted to let you know that I used the same AVS script intended for INTERLACED PAL (25fps) to NTSC (29.97fps) with a PROGRESSIVE PAL (25fps) DVD source.
The end result looked just as good (on my standard defination interlaced TV) as the other method (creating a progressive 23.976fps NTSC from a progressive 25fps PAL source).
I kinda like this method in that I did not have to due any audio conversion since the converted video matches the original audio.
For those without a progressive TV display (in other words you don't mind if the converted copy is interlaced) then I would say this method (creating a 29.97fps NTSC with unaltered original PAL source sound) is really the way to go.
As I said you couldn't really tell the quality apart on a standard defination interlaced TV
P.S.
Say ams30gts how did your audio conversion go? Hope it went well and you now have a DVD made"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
@DJRumpy
Xesdeeni, I haven't seen you post in a while...Just as an fyi, the frame rate conversion in BeSweet does a timestretch. I will compress, or expand your audio to meet the new framerate. It does not speed up, or slow down your audio (ala AssumeFPS in AVISynth). This avoids the change in pitch. It also takes a hit in quality, although I've never noticed it.Xesdeeni, the Farscape episodes used a 25fps to 29fps conversion. Created a weird telecine pattern, which was somewhat difficult to undo. I'd rather work on telecined 23.976 fps. Plus, it's not slowed down to 24.975, so this cycle is broken every now and then to compensate for the .025 fps drift.
if the authors were that worried about it, they should have shot in both framerates, although that would be expensive. Otherwise, I don't think they have no room to complain if they want their 'art' viewed in NTSC, and PAL land.Last but not least, be careful of the aspect ratio reading in DVD2AVI. I've run across many old 'widescreen' versions of old DVD movies that were actually encoded in 4:3 letterboxed, but sold as widescreen. Sometimes you just have to verify that what you see is what you get. Since I've got my widescreen TV, these are a dead giveaway. You can always crop the 4:3 letterboxing off to restore it to true 16:9.
@FulciLivesThat sounds like the ESS chip (at least I think that is the name of it). This is the chip used in most APEX/DAEWOO/SAMPO players and it always screws up the aspect ratio when doing PAL to NTSC conversion. If the original is 4:3 (full screen or widescreen) it will squash the image making everyone look too short and fat but if the original is 16x9 enhanced then it does the opposite and stretches the picture so that everyone is too tall and thin.Xesdeeni wrote:
Of course, if what DJRumpy says above is true, then this may all be moot.I tried to convert the trailer on the PAL DVD but unlike the movie the trailer appears to be interlaced.FulciLives
Posted: May 30, 2003 21:32
OK well I figured it out on my own hehehe
One thing that surprised me was that the video matches the original audio. THAT is VERY nice....got it to work just as you had it except I had to drop the line about convert to RGB otherwise I got a blank black screen in TMPGEnc. Is this because I had DVD2AVI set to RGB instead of YUV?All I had to do was run the program AC3Delay (a very small and free download I got from the DOOM9 website] to correct the -80 delay in the original PAL 2.0 AC-3 file and mux it (using TMPGEnc) with the M2V file that I created with TMPGEnc. Perfect sync and none of that BeSweet garbage.Just wanted to let you know that I used the same AVS script intended for INTERLACED PAL (25fps) to NTSC (29.97fps) with a PROGRESSIVE PAL (25fps) DVD source.For those without a progressive TV display (in other words you don't mind if the converted copy is interlaced) then I would say this method (creating a 29.97fps NTSC with unaltered original PAL source sound) is really the way to go.
Xesdeeni -
I've never tried a 25 to 29.97 audio conversion in BeSweet. I assume Xesdeeni's method is using pulldown, meaning the audio length should not change (Xesdeeni?).
(ps. You do realize it's much harder to type Xesdeeni than it is to type ineedseX?)
First of all, Fulcilives, thanks for all the help so far....it is seriously nice to know someone out there was actually able to pull off this painful process.
I've been attempting to follow the PAL DVD >> NTSC DVD tutorial on the website you pointed at earlier - http://www.geocities.com/xesdeeni2001/StandardsConversion/index.html (standards conversions on the cheap). I hadnt read this forum yet so I'm not sure if my dvd is interlaced or progressive but I've got a few questions -
- In the tutorial it says click the video only option - On my version of TMPGEnc I have two options for video only - should it be ES (video only) or System (video only)?
- If the audio on the DVD, is not surround, would we really have a need for the AC3 file - can we just click the "system and audio" option in TMPGEnc?
- Why not just output to mpg instead of m2v ? - what is the point of outputting to m2v? is it because a program like TMPGEnc cannot read the mpg file and then multiplex it with ac3/wav audio - i was under the impression this was possible so why again should the output be out to m2v?
- What is the avs file doing ?? - TMPGEnc is giving us the option of converting it into NTSC, i dont understand the role of the avs file if TMPGEnc is already doing the job of conversion.
Do most authoring programs read m2v - from what i understood, they can only read .vob, avi, mpg...why again output to m2v?
You'd said "At that point you can either mux the video and audio together (again you can use TMPGEnc to do this using the MPEG TOOLS section) to create a single filename.mpg or if your authoring software can read seperate files better to leave it that way
Using BeSweet you can convert the original AC-3 audio file from 25fps to 29.976fps ... - audio is audio - how can audio be a certain fps, this doesnt make any sense -do you mean it encodes the video with the audio?
Does the AC3 I got from DVD2AVI have to be converted from 25fps to 29.97? or will just converting the ac3 to wav do the same job? - Following this tutorial (http://forums.afterdawn.com/thread_view.cfm/9383) i used ac3decgui program for this, is that OK?
Thanks in advance.....im sure these are beginner questions for you now... -
As for the audio, it is not locked to the video in such a way, that each frame has it's own audio. Only the video is played back at XX frames per second. You could have any number of frames per second when using a telecine method, and the audio would stay exactly the same. Only when the video is actually sped up, or slowed down, do you see a change in the length of the video, which in turn requires a change in the length of the audio. In other words, 30 frames in a second, is still a second of video. 23.976 frames a second, is still a second of video.
Does the AC3 I got from DVD2AVI have to be converted from 25fps to 29.97? or will just converting the ac3 to wav do the same job? - Following this tutorial (http://forums.afterdawn.com/thread_view.cfm/9383) i used ac3decgui program for this, is that OK?Impossible to see the future is. The Dark Side clouds everything... -
That definitely answered more than a few questions...but I think I just messed up....My computer has been held hostage for the last two days - its been converting a three-hour long PAL movie into NTSC with the slowest high quality option - and on top of that I've been using the "System (video only)" option - its 68% done right now....should I just stop the encoding anyway and start all over with the "ES (video only)" option?
I've really got to start making a note of some of these gotchas so I can update my page. DJRumpy took care of a few, I'll try to take care of the others:
...should I just stop the encoding anyway and start all over with the "ES (video only)" option?TMPGenc will produce MP2/MPA audio. This is technically not to DVD spec.I've never tried a 25 to 29.97 audio conversion in BeSweet. I assume Xesdeeni's method is using pulldown, meaning the audio length should not change (Xesdeeni?).If the video is telecined from 25fps, to 29.97 fps, then the audio does not need to be converted. From the looks of this, it is a telecine process.
Xesdeeni -
Wait! Don't stop it on account of a wrong multiplex setting. You'll just end up with an MPG, instead of an M2V. No big deal. You can split out the video to an M2V using the MPEG TOOLS in TMPGenc. I wouldn't kill it just for that...
To pick a nit: MP2 is part of the specification for PAL DVD players, but for some reason it's not for NTSC DVD players. So PAL DVD players are guaranteed to play MP2 audio, while NTSC DVD players aren't, although in practice most do.. Even if you did have a big distribution of this to multiple people, chances are you'd be fine with MP2 audio.
Hello
Well this thread was rather busy since I checked it last hehehe
I'm now fairly confident that I understand the whole process. I think I will be using the progressive method when possible and the 25i to 29.97i method only when I need to use it (with an interlaced source). For me the audio conversion does not "bother" me for progressive PAL. Seems a shame to ruin a good progrossive source just for the audio. Though I don't have an HDTV/progressive TV display I hope too sooner than latter.
As for the audio it is my understanding that when ripping a DVD to re-encode the delay value for the AC-3 should be corrected to "0" if it originally was not. I've ripped many DVD discs and in my experience maybe only half are set to "0" already (i.e., straight out of DVD2AVI)
I did try the 25p to 29.97i method and it worked rather well but I did leave the SmoothDeinterlacer in the script. I only did a sample clip to see how it would look. It seemed that I got a 3-3 pattern (3 progressive then 3 interlaced repeated). The scene had a lot of motion in it but seemed to play back smoothly. Perhaps I'll try another sample without the SmoothDeinterlacer in the script but like I said if the original PAL is progressive I'd rathre just change the frame-rate to 23.976fps NTSC
I've heard that you can convert an AC-3 file to a WAV and then use some sort of WAV editor (such as CoolEdit Pro) to do the time stretch thing but that it also screws up the pitch. I never could figure out exactly how to do it. Seems like a pain in the ass too since you have to convert to the WAV ... resample/time stretch it ... then encode back to AC-3 or MP2 etc. I don't really have a problem converting 2.0 AC-3 to MP2 if need be but I want to keep 5.1 AC-3 files as 5.1 and the wave method means converting the 5.1 AC-3 to 6 different WAV files ... process each seperately ... then back to a 5.1 AC-3
Blah ... for that I'd rather just use the BeSweet frame rate AC-3 to AC-3 option.
@Xesdeeni
Great website but you should update it and make it more complete. For instance you mention BeSweet's use but don't say how to use it etc. I think we worked out a lot of things here that either were not on the website or were there but were too vague. It is a great resource so I'd like to see you make it even better. Perhaps even submit to this website for the GUIDES section.
OK well that is all for now
P.S.
I think you need to give up on that WSOLA thing ... doesn't seem it works too well."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by shetaan819
To split a single mpeg file (filename.mpg) into a video (m2v) and audio (mp2/mpa) file then you need to use Simple De-Multiplex which of course is under the MPEG TOOLS section in TMPGEnc
- John 'FulciLives" Coleman"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
oOps! sorry, i meant how would you use TMPGEnc to put the m2v file and the audio file together...
Again in TMPGEnc you would go to FILE --> MPEG TOOLS and select SIMPLE MULTIPLEX and then select your format ... there are only 2 choices for MPEG2 which is what a M2V file is and the choices are either MPEG-2 Program (VBR) which you use for DVD and the other is for SVCD
Nothing to it!
Seems a shame to ruin a good progrossive source just for the audio. Though I don't have an HDTV/progressive TV display I hope too sooner than latter....I got a 3-3 pattern (3 progressive then 3 interlaced repeated).
Progressive displays almost all include a deinterlacer. All over-the-air content is interlaced, so this is necessary to provide a progressive display for that content. So your interlaced conversion (25p to 29.97i), run through the deinterlacer of a progressive TV will look progressive, while on an interlaced TV, will be interlaced.
It seems a shame to have to convert audio when you don't have to. The only caveat of not changing the speed, is that on smooth panning shots, there may be some "jutter" or "bump." You'll have to judge whether you find this annoying (and whether you prefer ChangeFPS() or ConvertFPS() to minimize the effect). But for me, it is much less annoying than having to convert the audio AND re-encode the video.I did try the 25p to 29.97i method and it worked rather well but I did leave the SmoothDeinterlacer in the script.@Xesdeeni
Xesdeeni -
@Xesdeeni
Just to clarify ...
I took a 25fps progressive PAL source and converted it to NTSC (29.97fps) using the AVS script method "intended" for 25i to 29.97i
I wanted to see if it would work with a progressive source, what the quality would be, would the audio really match without being processed etc.
I found that the quality was very nice (although I left in the SmoothDeinterlacer because, at the time I tried it, I didn't realize it could be removed for a progressive source) and was very pleased that the audio matched up.
I had processed the clip in TMPGEnc (using a wav file converted from the original AC-3 but of course without a frame rate change) I ended up with a single mpeg file with video and MP2 audio muxed.
So I took that mpeg file and ran it through DVD2AVI to get a D2V project file. I opened the D2V in GORDIAN KNOT and looked at it frame by frame.
This is when I saw the 3:3 pattern (3 progressive, 3 interlaced, 3 progressive, 3 interlaced, and on and on).
That seemed kinda strange to me since I am used to a 3:2 pattern (3 progressive and 2 interlaced) when it comes to NTSC.
It did look very nice on my standard defination interlaced TV.
As far as wanting to keep progressive PAL (25fps) as progressive in NTSC (23.976fps) I was under the impression that a progressive source WILL always look better than an interlaced source WHEN you are using a progressive TV display, such as an HDTV display.
I understand that progressive (23.976fps) and interlaced (29.97fps) sources will look IDENTICAL on an interlaced TV but like I said above I thought that the progressive source will ALWAYS look better on a progressive display.
Am I wrong?
P.S.
I don't have a progressive TV display (unless you want to count my computer monitor hehehe) but of course I wish I did so this whole line of thinking is ... at least for me ... a look towards the future and wanting the best possible quality not just now but also when I upgrade to a progressive HDTV display."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I had processed the clip in TMPGEnc (using a wav file converted from the original AC-3 but of course without a frame rate change) I ended up with a single mpeg file with video and MP2 audio muxed.So I took that mpeg file and ran it through DVD2AVI to get a D2V project file. I opened the D2V in GORDIAN KNOT and looked at it frame by frame.This is when I saw the 3:3 pattern (3 progressive, 3 interlaced, 3 progressive, 3 interlaced, and on and on).
That seemed kinda strange to me since I am used to a 3:2 pattern (3 progressive and 2 interlaced) when it comes to NTSC.As far as wanting to keep progressive PAL (25fps) as progressive in NTSC (23.976fps) I was under the impression that a progressive source WILL always look better than an interlaced source WHEN you are using a progressive TV display, such as an HDTV display.
If you feed a 30i fps image to a progressive TV, the TV will deinterlace it to 60p fps. It won't be quite as good as it would have been if the video had originally been shot at 60p fps, but it will be much better than the 30i fps on a regular TV.
But the more important thing is that it will almost certainly look better than the 30p fps you could have chosen. The reason is that the TV will only be able to show 30p fps with a 30p fps source. It can't figure out what to put between the 30 frames you provide, so it will duplicate them. But if you had provided 30i fps, it could have used the information in the 60 fields to construct 60 whole frames.
Xesdeeni -
Ive been to these posts quite a few times before so now ive got a new project
I have a movie trailer and its encoded in
4 : 3
20 fps
PAL
Interlaced
I want to try to convert it to
4 : 3
NTSC Standard 24 fps
Interlaced
Can I convert it with only video equal to 20 fps? -
Nvm bout the 20 fps
Once I output to d2v and load into Dvd2Avi again it reads 25 fps
Anything special I have to do for interlace PAL to interlace NTSC
I believe the file is svcd not sure....its a trailer so -
I don't know if this will help but I have taken multiple SVCD's (PAL) to DVD (NTSC) and here's how.
FOR MULTIPLE SVCD's PAL (480x576) to NTSC DVD
-Took .cue/.bin to make MPG's
-Used TMPG to join clips together to make one MPG
-Exported the WAV from the "fullmovie" MPG
-Loaded in DVD2AVI and "save project as" (couldn't load mpg in TMPG for some reason)
-Loaded .dv2 into TMPG and unlocked template
-Encoded as video only at 352x480, pulldown, 23.976 fps, do not frame rate conversion checked
-Took WAV file and loaded into BeSweet and converted from PAL to NTSC and to .mp2 (have done ac3 as well)
-Loaded .m2v and .mp2 into Maestro and authored DVD.
Everytime it has worked like a champ.
A side note question I have is:
Since the SVCD source is 480x576 (PAL), I have always re-encoded to 352x480 rather than 720x480 (NTSC), to fit more on DVDR at higher bitrate.
My question is, is that what you all would do, go down to 352x480 rather than 720x480? I'm guessing there would be some quality loss if going up in resolution (work too much with photoshop)?
Hope this helps and interested to find out about resolution change. -
Yea I think I could do it that way but I want to try using AVISynth so if anybody can help me out ....current AVS script
LoadPlugin("C:\Program Files\AviSynth2\MPEG2DEC.dll")
LoadPlugin("C:\Program Files\AviSynth2\SmoothDeinterlacer.dll")
MPEG2Source("C:\Documents and Settings\*****\Desktop\Test.d2v")
LanczosResize(480,480)
ChangeFPS(23.976) # Frame Conversion
SeparateFields()
SelectEvery(4,1,2)
Weave()
ConvertToRGB()
Im trying to take an interlaced PAL svcd and convert to NTSC FILM svcd using AVIsnyth -
Originally Posted by Bluesilo
BUT
You CANNOT convert an interlaced PAL source to progressive NTSC (23.976fps)
An interlaced PAL source can only be converted to interlaced NTSC (29.97fps)
P.S.
There probably IS a way to do it but it would require some sort of deinterlacing that would ultimately degrade the image. Better to go with interlaced NTSC than deinterlaced reduced quality progressive NTSC."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I have never had a problem with PAL SVCD to NTSC DVD (pretty much same as DVD to DVD). Sometimes I had no idea if the source was interlaced or progressive. I am gaining a better visual prospective of the whole thing, but when you load the source in TMPG, it should list your source settings but it is NOT always correct. I sometimes try encoding both ways, non vs interlaced. Can't really tell the difference, but you tell me. I'm always willing to learn something new everyday.
In addition, any suggestions on my post about resolution (3 posts above)?
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 17:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
