I recently downloaded an encode of a Roswell episode. The info at the end of the file name is svcd.sc and the file type is .mpg, a Stonecutters encode. Viewing the file with either WMP or PowerDVD 4.0 gives only garbage audio and video. The problem seems to be that the Stonecutters included menus and bonuses with the normal video. I can page through some of the extras frame by frame using WinDVD, but if I simply play it, it skips past about 10 frames and stops.
I also tried burning the video in SVCD format with both Nero and VCDEasy, and neither provided useable results. The problem with this is that it burns the entire file as a single video and doesn't recognize the menus as anything beyond more video frames.
Does anyone know what's needed to interact with the menus? I've been working on this for several days, and I'm stuck. Thanks.
