I own a cheap AVerDVD EZ Maker. After installing the card, I plugged my S-Video cable into my camcorder, then into my capture card, and captured video, but it was in black and white!
Composite video captures in color fine, but I want to use S-Video for higher quality.
YES, I've checked to make sure I'm capturing in NTSC since I'm in NTSC land. YES, I've check the cable, all pins are intact (in fact, the cable's gold plated). YES, the settings seem to be all correct; I was using Ulead MovieStudio. YES, my camcorder is fine since my other even cheaper capture device captured in color.
Advice anyone?
Thanks!
Results 1 to 14 of 14
I remember I had a similar problem with my ReplayTV. The problem was that somehow my S-Video cable went bad...it had worked before, but somehow the cable started only putting out Black & White.
Moral of the story is, try a different cable, you might be suprised...
Regards,
Ivan -
I have the exact same capture card and capture from the s-video output of my JVC VHS recorder (rare to find a VHS with s-video out). It works great for me so my guess is a bad cable, or perhaps you just got a defective AVer capture card.
Actually, I should've mentioned that when I used the S-Video cable to test with a VCR, and then capture some video with a DVC 80, it worked fine and in color. So it seems like it isn't the cable.
Too bad I can't exchange the card being that:
1.) AVer's tech support really stinks
2.) I misplaced the Installation CD so all the pieces aren't intact
3.) The UPC is gone because I sent it in for a rebate
Advice anyone?
Thanks! -
I'd still try a second cable...if the second cable doesn't work, then you'll know it's a defective S-Video input on the card.
Good Luck!
-ivan -
Na, took a look at the card. It's clean, no foam, no dust, no nothing!
Advice anyone?
Thanks!Rule 11
Be nice to nerds. Chances are you'll end up working for one.
-Bill Gates -
It really is a bad C pin on one of your cables or ports. Really. Anyone who has done extensive use of S-Video devices knows this one. You have hot wires in your S-Video cable. Y and C. The C wire is not making a connection somewhere. If you try multiple cables and it's the same and the VCR outputs in color over S-Video to other devices, then it is the connector on the card.
Hmm, must be the card because the cable works fine everywhere else. Unfortunately, I can't exchange the card since I lost the installation CD, and the UPC label is gone when I sent it in for a rebate. DARN!
Any other advice?
Thanks!Rule 11
-Bill Gates -
dude
i have tried 3 different cap cards, and the most expensive and cheapest S-Video cables ever (at least 10 of them) and I have NEVER been able to get a colour picture ...
so worry not, its not just you !!
i have to use composite also
" Your gonna need a bigger boat .... " -
Yeah, the question is IF. CompUSA's policy requires that all parts be in the box when you return it. I'm not sure if I can send it directly to AVer. Their offices are literally down the freeway from me, but is it worth is to pay for shipping and stuff on a card that's worth $10?
Rule 11
-Bill Gates -
If it is within the timeframe of CompUSA return policy, just ask them if they can swap the card from a new box. Explain to them that they can keep the box, UPC, CD and everything else from the new box. Just simply exchange the card itself. Same as if you bought another retail box from them and just did it yourself and returned the bad card in the newer packaging.
Or purchase another and swap out the defective one when returning it. Hopefully, the second one will work since you'll still be stuck with one.
S-Video Vs Composite for Black & Whit captures
By nharikrishna in forum Capturing and VCRReplies: 29Last Post: 8th Sep 2011, 23:30 -
Software that captures audio from video source
By MrIronsides in forum Capturing and VCRReplies: 3Last Post: 11th Mar 2010, 18:42 -
VDub captures in black and white. NO color. SOLVED BUT NO AUDIO NOW
By bradyfan123 in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 20:04 -
SCART to S-Video or Composite converter drops color
By chupacabra in forum Capturing and VCRReplies: 28Last Post: 2nd Nov 2007, 17:32 -
Lip sync on video captures using VIVO card
By Confused Chimp in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2007, 18:36
