I need to convert did rips to avi so i can use them for editing, cutting and joining scenes, etc. I need a program that can go to an uncompressed avi or any avi except divx so i can use it in editing programs like tmpgenc. I tried one called dvd to avi but it did not work corrrectly. Any help would be most apreciated. Thanks.
The easiest method is using DVD2AVI (I'm not sure if this is the one your referring to or not). Make sure you get version 1.76. If you can't find it here, get it from www.doom9.org
You can then save the output as a project file. This project file can be frame served to any encoder/editor, so you don't have to save an AVI file. It can be converted directly from VOB to whatever you want to output, skipping the AVI step completely.Impossible to see the future is. The Dark Side clouds everything...
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
