How do you use AC3Fix? It is a dos command.
Results 1 to 9 of 9
Removes bad frames from .AC3 files
Usage: ac3fix <infile> <outfile>
Error level returned:
0: No bad frames found
1: One or more bad frames found and removed
2: Error in execution
open a dos windows and do the above -
re: your other post -- it may be also you have a bad header in your ac3 file and i not sure what you can do about that ... try ac3fix and see if what happens .
Thanks, will try. I apologize for the double post but they were kinda different subjects. Just trying to do the right thing.
no problem -- i didnt mean there was a problem regarding a double post --
-- they are different subjects but tied together now . -
I take that back. I forgot to add the extensions on input and output file.
It comes up with no bad frames encountered -
I guess i should wait until i try everything out before i post. Even though it found no bad frames, DVD Architect now sees the new file.
AMAZING.
When is the new donation collection. I will surely send something. I don't have much but what i have i will give to you cause it appears that this is what you guys do.
Thanks.
Sync issues after fixing with ac3fix
By mub6 in forum AudioReplies: 5Last Post: 24th Dec 2007, 08:56 -
Aften vs Besweet vs Super vs AC3Fix vs working
By awesomer in forum AudioReplies: 2Last Post: 18th Nov 2007, 19:28
