I have two problems usaing TMPEnc to convert AVI files to S-VCD for use on a DVD-Player (TMPGEnc 12j):
1.) A new AVI that I have received (it seems to be encoded with the new Divx4.1) is not accepted by TMPEnc ("... not supported". What can I do ??
2.) I converted a lot of AVIS to either VCD or SVCD, but always the same problem: There are several points in the movie when video and audio go out of sync, the video runs very fast for a moment and then v and a are out of sync for a couple of minutes. I have read a lot of how-to's but never found a solution. For example, the default template for pal-svcd sets TMPEnc to "constant quality", but the how-to's on this page suggest to set it to a constant bitrate (you have to calculate the bitrate first according to the lenght of the video)
Does anybody have a clue for me?? Thanks a lot!!!
_________________
<font size=-1>[ This Message was edited by: mperathoner on 2001-09-20 23:18:16 ]</font>
I had the same problem with TMPEnc.
Then i removed Divx-codec 4, and installed divx 3.11 again.
And from then i had no problems at all.
The problem seems to be with Divx 4.
Try frameserving it, either with AviSynth:
-Get and install AviSynth
-Create an .avs file:
AviSource("C:\YOURDIR\YOURMOVIE.AVI"
ConvertToRGB
-Open the .avs file in TMPGEnc.
If that doesn't work, frameserve from VirtualDub:
-Run AuxSetup.exe from your virtualdub directory
-Install AVIFile frameclient support, exit
-Launch VirtualDub, load YOURMOVIE.AVI
-From the "File" menu select "Start frameserving"
-Accept the default name (usually YOURMOVIE.AVI)
-Save a .vdr file. YOU MUST TYPE THE FILENAME
INCLUDING THE EXTENSION (i.e.: YOURMOVIE.VDR)
-Open YOURMOVIE.VDR from TMPGEnc. -
On second thought, it might be enought to use
the AVI VFW compatiblity reader instead of the OpenDML
reader.
****TRY THIS FIRST**** instead of frameserving:
-Launch TMPGEnc, ->Environmental setting, ->VFAPI plug-ins
-Right click, bump the AVI VFW compatiblity reader
to a priority of 0.
-Lower the OpenDML reader to -1
-Lower the DirectShow File reader to -2. -
@mperathoner for you second question
This sound like the typical "SVCD offset scans" bug of tmpegecn...
You see, tmpegenc don't add some frames, which helps for the synch between A/V.
One solution is de multiplexx the ready mpeg-2 file with tmpegenc, and then re-multiplexx it with BBMEG, as a SVCD....
That fix the problem.
For "how to", see the guides.... -
thanks for all Your responses
To MuTTLeY: I cannot delete Divx 4.1 since the newer avis I have received are encoded with it ant won't run with 3.11!
to Tlaloc : thanks!! Your "second thought" did it, the avi is now accepted!!
To SatStorm: thanks for Your advice, I will give it a try!!
DO YOU RECOMMEND - when converting an avi to svcd with TMPEnc - leaving the Settings to "constant quality", which is the default, or to change it to "constant bitrate", as advised in the VCDhelp to-do ???
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44
