I downloaded three audio files and can't hear any sound. I loaded them in Virtual Dub and the file imformation says they are DivX 4.12. I had DivX 5 installed already and it wouldn't play the audio for these files. I went out and downloaded/installed the 4.12 DivX but still no sound. I open the file in Windows Media PLayer and it says the codec can't be found. The files I downloaded end with the word postx if that means anything. Can anyone assist?
Thanks!
Divx is a video codec, you apparently need an audio codec. Get Gspot from the Tools section of this site and test your file. It will tell you the required audio and video codecs and if you have them installed. 8)
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks, that utility did the trick. Sorry about the audio/video mix-up. I probably should have stuck to the newbie section! Thanks again for the help!
You're welcome!
DivX Audio problem which has always bugged me..
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2011, 08:36 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 17:53 -
DIVX DVD Player Audio Synch problem
By wulf109 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Mar 2008, 08:14 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 04:13
