I have an .AVI file :
Video : 582 Mb, 944 Kbps, 23.976 fps, res. 640*352 (16:9), DIVX = OpenDivx v4,
Audio : 118 Mb, 192 Kbps, 48000 Hz, 2 chan., 0x2000 = AC3 DVM, for audio. Both are supported.
I used VDub to make a new .AVI file (direct stream copy) and new Audio file (direct stream copy and rename to .AC3 as mentioned on many post).
Video is fine, i've already encoded it as video only (MPEG not M2V) with tmpgenc. It loads fine in my authorer.
Problem - Vegas Video or DVD Architect will not accept the AC3 file. Yes the video and audio files are both the same name. It says an error occured during operation. If i try to mux the 2 files with Tmpgenc it says Illegal mpeg audio stream.
What can I do with this AC3 audio file?
Yes I can play the file alone with no problem. No i did not try ac3fix. Are you telling me I should?
Can't Import Video File with AC3 Audio into Vegas 9 Platinum
By Charlie_L in forum Newbie / General discussionsReplies: 11Last Post: 2nd Sep 2011, 08:44 -
Is there something better than DVD Architect 5 to use with Vegas Pro?
By ingeborgdot in forum Authoring (DVD)Replies: 11Last Post: 12th Dec 2010, 21:46 -
Can't import AC3 to DVD Architect?
By zovx in forum Authoring (DVD)Replies: 9Last Post: 11th Feb 2010, 19:53 -
AC3 problem in DVD Architect
By blackberryf1 in forum Authoring (DVD)Replies: 0Last Post: 1st Mar 2008, 10:25 -
Sony DVD-Architect won't load markers in mpeg file rendered in Vegas
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2008, 11:01
