I have some DIVX5 clips that I am trying to convert to VCD's. The problem I am having is that when I use FFMPEGX to do the conversion the sound is out of sync. I am using DIVX Validator before I run them through FFMPEGX, so they start in-sync and they end up pretty bad.
Also, the picture quality is not as good. Is there a better way ?
-Squeed
The diffuculty is you have to pick the SAME frame rate and other encoding specs that were used to make the DIVX in the first place. If you didnt do it youself it can be an endless guessing game. The EASIEST WAY, is to validate, open in quicktime and export as a TOAST VCD. Ensure you split your divx into two first!Originally Posted by squeed
You can either do that 1 of two ways,
Use the Split function of FFMPEGX
or use Quicktime to choose the first half, copy, paste into a new movie and repeat for 2nd half. Export each to TOAST VCD and you have your mpeg file that will be accepted under TOAST VCD option.
QUALITY ISSUE
crap in is crap out. Thus, whatever the quality of the divx is the MAX quality of the VCD you can get. sorry. But one thing that will help:
Your monitor is most likely much higher resolution than your TV, so it will look better when you do watch the VCD on the tv than it looks when you watch the VCD on your mac! (thats a plus)
File .avi can't work on my new MP4 player
By jj_rouge in forum MacReplies: 14Last Post: 10th Aug 2024, 23:12 -
Trying to get AudioDub to work with .mp4 and .wav!!!!!
By Nagashi in forum EditingReplies: 1Last Post: 29th Dec 2010, 18:33 -
Why won't this MP4 work on my Xbox 360?
By Jhay in forum Video Streaming DownloadingReplies: 2Last Post: 20th Dec 2010, 10:31 -
Mov to mp4 won't work
By Klagar in forum Video ConversionReplies: 1Last Post: 15th Dec 2010, 12:07 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 08:30
