For some reason,my computer does not burn VCD/SVCD that will play on my Stabdalone DVD player, even thought it used to a couple of weeks ago.
I asked a number of people, tried various media and tried every setting on various burning software, nothing works.
The VCD/SVCD still playon my computer and Apex DVD player but not on my Sony now. The "Bad" VCD/SVCD look different than the "good" one I burned before, they are lighter in color at the rims after burning.
Anyone ever see anything like this?
I was doing great with VCD/SVCDs for a while then suddenly no more Sony DVD player compliant ones, I put it in andht eSony DVD player says "insert disc". No error it is just not there.
Problem is your SONY dvd-player. It's commonly known that Sony doesn't accept cdr/cdrw - if it should to, contact your dvd-supplier.Originally Posted by ipgpe13
If you don't trust the burning process of a (s)vcd, then burn at a lower speed. I've had some strange rusults in the past (with cdrDAO) when I burned at a speed too high (like 16x). When I lowered the speed to 12x or even 8x, the disks were 'normal' again... -
It is not the Sony DVD player. I was have been burning VCD/SVCD that played in the Same Sony player with no problems, with the same sofware and media.
I has to be a windows problem. Like we mentioned above, the CD-R that were burned after the problem started actuall look different now. -
Tried burning at all speeds too, no good.
Found another person on the forum with the same problems using different , player, hardware and software. This has got to be a change in the way our CD-Rs are being burned.
Weird (to me) subtitle problem
By alvabass in forum SubtitleReplies: 3Last Post: 31st Dec 2011, 14:50 -
DVDStyler weird problem
By xeroblast in forum Authoring (DVD)Replies: 0Last Post: 8th Sep 2011, 02:37 -
Weird HDMI problem
By WinSpecToR in forum ComputerReplies: 6Last Post: 29th Sep 2010, 05:22 -
weird computer problem
By deadrats in forum ComputerReplies: 23Last Post: 24th Jul 2009, 20:10 -
a weird memory problem
By ahhaa in forum ComputerReplies: 3Last Post: 6th Nov 2008, 11:15
