Bought a Matshita SR-8587 some weeks ago, at first I could rip at 6X - 8X any DVD, now sudenly the ripping speed droped for 1.6X - 1.7X maximum .
I did not made any changes to the pc harware configuration, and don't think any to the drivers also.
I have a PIV 1.5 512DDR the DRU-500 in secundary IDE as master and the Matshita in secundary IDE as slave (the same configuration that when did rip at 8X). Window XP Prof. Edition
In the control Panel I can not change the Matshita to go DMA (DRU-500 is "Ultra DMA mode 2") the Matshita say "DMA if possible" but below does not change from "PIO Mode"
I have just tried to delete the driver ( "storprop.dll" / "atapi" ) files and rebbot the pc but it all satys the same .. and the speed is still 1.7 maximum !
Also have S.M.A.R.T. mode disable ( should I ? )
Can anyone help me please ?.. thanks
Simple, Delete you IDE Controllers and restart your computer.
SLICK RICKOriginally Posted by lordsmurf -
After you do that it should bring your ULTRA DMA MODE from 2 to 5.
GOOD LUCK,
Thanks for the reply but ..
... deleting "storprop.dll" / "atapi" shouldn't the controllers be deleted ?
How should do I delet the controllers/drivers for IDE ?! ( I have Win xp )
Thanks SLICK -
It's in the hardware manager. Right click on the my computer icon and go down to properties. There should be a 'hardware devices' button, click that, look for the IDE controllers. Delete them, restart. XP will reload them at reboot and that solves about 99.9% of ripping problems
Finally !!
I was triyng to delete the files manualy, did not understand that had to UNINSTAL it.
Thanks very much to both of you !gonna rip now ...
Originally Posted by SLICK RICK
DMA2 is ATA33. if you use a 40wires IDE cable, it's the max you can go..
Simple 1-step DVD/Blu-Ray ripping?
By billbo1970 in forum DVD RippingReplies: 17Last Post: 29th Dec 2011, 11:59 -
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 05:45 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 13:04 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 02:49 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
