    Jul 2001
    Maryland
    Can someone recomind a good router that's not to expensive (i can't go over 100 really, i'd like to keep it round 50-80)
    I need:
    Brodband connection sharing, VPN, file and print sharing.
    I want:
    A USB port so i can run my usb printer right off the router
    A Firewall that either auto-detects what ports an application needs and allows them to open, or easily allows for opening of ports and port ranges.
    Wireless connectivity (not needed but a plus)
  2. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Well, if it wasn't for the USB print server, I would say look at the linksys products first. Then D-link products. If you ditch the wireless and printer the Linksys 4 port router is rock solid and around/under $50. You could then add a print server box, and then wireless access point later. Somebody had a sale on the Linksys wireless kit for notebooks. I think it was around $99.00 after rebates.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  3. Dlink is great, free 24/7 support if you happen to need it. Which I ended up needing, and on a Sunday I was able to get a person and help in less than 10 minutes. I love those guys.
    "Sleep-
    Those little slices of Death;
    How I loath them."
  4. i've got a linksys befsr41 router here that has been going strong for over a year now.. the only problem i've had with it is that i cant transfer files through aim.. but aim file transfer works through trillian.. must be something weird with aim.. aside from that the router is a champ.. it just sits there doing its job & collecting dust from no one paying attention to it.. which is exactly what it should be doing.. it cost me $99 + tax at office depot.. last time i saw one in a the newspaper circular it was $79.. it may be cheaper now.
    Jul 2001
    Maryland
    I forgot to mention
    I'm asking this because I had a DI-604 and it was a piece of shit. Terrible firewall, it took forever to open ports.
    It also would only run 100 Meg Ethernet w/ certain modems. I couldn't use 100 on a 50 foot cable, Cat 6 gigabyte ethernet grade.
    Do any routers have USB print server?
  6. Member The village idiot's Avatar
    Apr 2002
    I don't know about the USB on a router, but I think you might be able to get a cheap ethernet print server that has it. I was in Walmart today and noticed that they have a Linksys 4 port plus wireless router for $89.99 regular price. It will only do 11 Mbps wireless, but it is a good start. Also several other brands of routers at Walmart, some very cheap.
